12-01-2021, 11:51 AM | #1 |
2016-2019 Camaro Blackout Kit - Front/Rear/Reflectors Lights
2016-2019 6th Generation Camaro Light Blackout Kits
https://www.rpidesigns.com/shop/item...ar-reflectors/ If you own a 2016-2019 Camaro in black, silver, red, or yellow then in our opinion light blackout kits are a must. Nothing looks better than a set of darkened side markers, or reflectors on the sixth-generation Camaro. If you team these blackouts up with one of our SS satin black front splitters the look is absolutely phenomenal. RPI Designs is excited to release our exclusive 2016 - 2019 6th Gen Camaro light blackout kits. We offer our kits in a thin vinyl (as shown in the photos). We also offer these light blackouts in a thicker smoked acrylic. Our light blackouts are a great way to give your Camaro a sleek look. Blackouts look great on a number of different colors, from black, red, silver, yellow, white and more. We offer these kits in pieces and parts. You can select the side markers, front and rear, the rear reflectors and the third brake light. The choice is yours to make. You can also order these 6th Generation Camaro blackouts in the vinyl or acrylic. Vinyl is similar to a sticker and acrylic is a hard plastic and has 3M (clear) tape built into the back of each piece. If you select the acrylic package and also need a piece for the 3rd brake light please note that we send you a vinyl piece for that 3rd brake light as the acrylic is too thick and doesn't look right. The vinyl looks really good. To add the third brake light select it from the drop-down box (Options if purchasing an acrylic kit). Frequently asked questions: *What material are these Camaro blackouts made of? -These are available and made of either a plastic smoked acrylic, or a PVC vinyl and a smoked finish. Both style blackouts come with adhesive on the back for a quick and easy installation. *Can I remove these tint kits down the road? -Yes, the adhesive is semipermanent, but with time and patience, you are able to remove either version acrylic or the vinyl. Leaving your Camaro-looking factory as it came from the assembly line. Fitment: 2016, 2017, 2018, 2019 Chevrolet Camaro Last edited by RPIDon; 10-28-2022 at 02:00 AM. |
02-02-2022, 08:07 PM | #2 |
What about ’22s?
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions |
02-04-2022, 06:38 AM | #3 |
Drives: 2022 Camaro SS, F350 platinum Join Date: Jan 2022
02-04-2022, 02:46 PM | #4 |
Drives: 2021 3LT RS A10 Join Date: Nov 2021
OR even '21s?
02-04-2022, 03:34 PM | #5 |
Drives: 2021 LT1 Join Date: Nov 2021
I tried asking I before I bought this set and didn't get an answer. I rolled the dice. They do work on a 21 but not as dark as I like. I put the phastek set on. Also the 3rd brake light does not fit.
02-04-2022, 05:11 PM | #6 |
It would fit, but the color won't be accurate, it could look odd.
04-19-2022, 03:21 PM | #7 |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
08-06-2022, 07:58 AM | #8 |
Drives: 2018 Grandsport Corvette Join Date: Apr 2022
I almost ran into the back of a newer Chevy truck with darkened taillights.
So no thanks for me. I want to be seen at night.
2022 Orange ZL1
4/07/22 7-01-22 Past 2018 Gransport 2018 GT Premium 2009 ZO6 2008 Z-51 Vette 2001 Stroked/ blown C-5 2001 SS 1998 SS vert. Garage 2020 Range Rover V-8 2021 Ford F-150 Platinum Powerboost |
10-28-2022, 02:02 AM | #9 |
Thank You for shopping at https://www.rpidesigns.com/shop/item...ar-reflectors/
