Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 10-20-2021, 01:38 PM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
2016-2019 Camaro 6th Generation Splash Guards - Stealth
2016-2019 6th Generation Camaro Stealth Splash Guard Kit - Mud Flaps / Mud Guards
(Patent Pending Design)
This 2016-2019 Camaro splash guards kit includes four splash guards, two for the front wheels, two for the rear wheels. No drilling, glue or tape required. These 6th Generation Camaro splash guards use stock hole locations to mount in combination with provided clips. You can even install these without removing your wheels!
We now offer these splash guards in a thicker premium plastic that is nearly twice as thick as our regular splash guards for the ultimate in durability.
6th Generation Camaro Splash Guards / Mud Guards Installation:
The 2 front splash guards require the removal and re-installation of 1 push style pin per splash guard. We also include one "U" clip to secure the top of the flap. Installation is much easier if you turn your wheel to allow you to easily access the push style pin. Simply remove the pin with a flat screwdriver. You'll see a small notch in the pin, use the screwdriver to pop that loose. Then pull the rest of the pin out. The pin is actually a two piece unit.
Now place the splash guard into position, push the large part of the pin through the hole in the splash guard until flush with the fender liner.
Next take the rest of the pin and tap it into the large part of the pin which is now installed in your Camaro fender well.
Lastly, take one of the two “U” clips and install it near the top of the splash guard, burr to the back of the fender lip.
The 2 rear splash guards include new bolts that are slightly longer to accommodate the splash guard.
You'll remove the two bolts shown in the picture above and install the new bolts in their place. Use the provided Torx head wrench to remove the two bolts.
Put in the new bolts and tighten with a standard socket. Do not overtighten.
The rear splash guards have a block built into them to push them 1/4" away from the fender liner to create a sleek appearance.
These splash guards (mud flaps) are made for the 2016-2019 Camaro, they are not a universal splash guard kit. These were designed to follow the body lines of the Camaro and to remain almost unseen.
All hardware is included along with the proper screwdriver for a very simple installation. These Camaro splash guards / mud guards are also available pre-painted to match your Camaro. Please email us for more information.
Fitment: 2016, 2017, 2018, 2019 Chevrolet Camaro
RPIDon is offline   Reply With Quote
Old 10-20-2021, 06:50 PM   #2
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
I have these and can vouch that they work very well to block rock chips (they hang down lower than other brands of rock guards).
That said, shouldn't this post be in the vendor section rather than here?
N Camarolina is online now   Reply With Quote
Old 10-20-2021, 07:29 PM   #3
Callaway SC630
Callaway SC630's Avatar
Drives: 2020 Callaway Camaro SC630
I have them and like them. Forget they are even on when walking toward the car.
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue
Callaway SC630 is offline   Reply With Quote
Old 10-22-2021, 04:31 AM   #4
Chevelle vs Camaro
Chevelle vs Camaro's Avatar
Drives: 2018 Camaro SS
No link?
Chevelle vs Camaro is offline   Reply With Quote
Old 12-09-2021, 02:56 PM   #5
RPIDon
RPIDon's Avatar
Drives: Camaro
Originally Posted by Chevelle vs Camaro View Post
No link?
Here... https://www.rpidesigns.com/shop/item...rds---stealth/
Old 12-10-2021, 05:48 AM   #6
NashZL1
Drives: 2022 Camaro ZL1
Will these work on a 2022 ZL1?
Thanks!
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10
2020 Ford Mustang Shelby GT500
2020 Genesis G90 Ultimate
2019 Mercedes-Benz SL450
2017 Corvette Grand Sport A8
2016 Hyundai Equus Ultimate
1971 Datsun 240Z
NashZL1 is offline   Reply With Quote
Old 09-07-2022, 02:27 PM   #7
wang0528
Drives: 2021 2SS
will they fit 19+?
wang0528 is offline   Reply With Quote
Old 09-13-2022, 09:07 AM   #8
PFYC
PFYC's Avatar
Drives: Yes
Originally Posted by wang0528 View Post
will they fit 19+?
Yes, They will.
PFYC is offline   Reply With Quote
Old 11-04-2022, 06:17 AM   #9
RPIDon
RPIDon's Avatar
Drives: Camaro
Thank You for shopping at https://www.rpidesigns.com/shop/item...rds---stealth/
