Old 02-02-2020, 05:57 PM   #15
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Originally Posted by Smoke in View Post
I needed to get the EXT. 5000 version to lift my 18 1LE properly.
Just saying!
My 5000SLX seemed to lift my 2SS just fine, didn't feel unsteady at all...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires
Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph...
Old 02-23-2020, 02:02 AM   #16
LSA
Drives: Fast
Are the panels underneath a 1LE and non 1LE the same?
LSA is offline   Reply With Quote
Old 02-23-2020, 06:13 AM   #17
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
[IMG][/IMG]
This was my 2017 1SS on the Quick Jack 7000 SLX when I had it, you can see where I placed the jack pads, I have yet to use the Quick Jack on my 19 ZLE but I think that there will be no issues.
warren3537 is offline   Reply With Quote
Old 02-25-2020, 09:48 PM   #18
OzzieSS
OzzieSS's Avatar
Drives: 2016 Camaro SS
I used a Quickjack for a couple weeks but I quickly realized me crawling under the car was gonna get old really quickly. Especially since I'm in a wheelchair which makes it even harder. So I returned the Quickjack and I went full blown four post car lift. I love it!
OzzieSS is offline   Reply With Quote
Old 03-27-2021, 09:57 AM   #19
NotFast
Drives: 2021 LT1
Sharing my QJ experience/picture. After some help via PM from @2SS Capt and @M1nd64m3, I finally got mine in the air.
I used ZL1 Jackpads and the SLX extension kit (which I bought for another car, wasn't totally intending on using it with the Camaro). The biggest issue I ran into was exactly WHERE to mount the Jackpads on my LT1 and lift - the further front and rear points were slightly too far apart even for the SLX. The back point has a lot of plastic around it and none of the QuickJack blocks would fit (2SS Capt said he used a hacksaw to one of the supplied pads to rig a solution).
NotFast is offline   Reply With Quote
Old 03-27-2021, 01:33 PM   #20
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
Just seemed like in some reading people being concerned with them vibrating loose while driving, hate to have one depart while on the road.
They will NOT come off.
I have 40k miles on my 1LE and the lift points have been on since day 1.
I track my car often. They just don't move.
I have 6 on mine. There are three lift points per side.
The -5000 works fine. You don't need the extension.
If you don't want the lift points, you MUST get something that will work with the pinch welds. The QuickJack pinch weld blocks are not great for the Camaro. The cutout for the pinch weld is ok, but the block is too wide for the skirts.
A set of hockey pucks will be your friend. Add those to the blocks that come with the QJ and you won't have any problems. I have a slight slope to my garage floor, the blocks+pucks help me get the car perfectly level for the lift.
For an on/off solution...
https://zl1addons.com/collections/ja...-3-jack-magpad
These make positioning the QJ much easier.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
Old 03-27-2021, 01:40 PM   #21
MatthewAMEL
There are 3 lift points on each side. Absolutely no reason to cut anything. Extension is NOT needed.
I understand that lifting a car can be a nerve wracking experience. Even more so when you actually go to get under the thing and start applying torque.
The only time I have used a 'belts and suspenders' approach to the QJ was when I was installing the ZLE rear cradle bushings and had to drop the rear-end of the car. Just because I wanted to have no fear, I put two jack stands under the front-most lift point while I dropped the rear. The car never moved and wound up with no weight on the front stands.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
Old 04-15-2021, 08:19 PM   #22
koolkat68
Drives: 2022 Vivid Orange Metallic LT1
I have the extended version of the quickjack. It reaches the back and the front most jacking point.
koolkat68 is offline   Reply With Quote
Old 04-15-2021, 09:45 PM   #23
GAOLDGUY
GAOLDGUY's Avatar
Drives: 2012 GMC Sierra, 2018 Camaro SS 1LE
Which Quickjack?
I realize the thread title is 5000 but are you using a 5000 or 7000? I also have a GMC Sierra Crew Cab truck so I was thinking of getting the 7000 but can't decide if I need the extension with the 7000.
GAOLDGUY is offline   Reply With Quote
Old 04-15-2021, 10:00 PM   #24
Brudda*Termite
Brudda*Termite's Avatar
Drives: 2017 Camaro 2SS
I have the Quickjacks 5000 and just use the blocks that are supplied you drop into the trays, I put my car up in the air about 5 times a year. Takes a couple of minutes to align everything and you're good to go, no need for the permanently mounted thingies my opinion
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon
Brudda*Termite is offline   Reply With Quote
Old 04-15-2021, 10:06 PM   #25
43Camaro
43Camaro's Avatar
Drives: [COTW 8/3/15] 2010 Camaro SS L99
No problems at all with 5000, had it up 7 times already..
A Little bit of power. ALL WORK DONE BY ME!
Just added 2021 ZL1 1LE to the Stable!
https://www.camaro5.com/forums/showthread.php?t=418273
43Camaro is offline   Reply With Quote
Old 08-02-2022, 07:19 PM   #26
Jm_rea
Drives: Chevrolet Zl1 1le
Is anyone using 5000TL or TLX? I'm not finding the sl, slx, or ext on the Quickjack site.
Jm_rea is offline   Reply With Quote
Old 09-03-2022, 12:56 AM   #27
Val Walkinshaw
L8ap3x
Val Walkinshaw's Avatar
Drives: 2018 2SS 1LE
Yes
Picked up the 5000TL earlier this year. Have used it half dozen times. No issues.
Val Walkinshaw is offline   Reply With Quote
