Old 04-12-2018, 10:13 AM   #15
BrianL
BrianL's Avatar
Drives: 2016 2SS, Red Hot, NPP, Nav, M6
I was able to do mine in my garage with the car up on jack stands. Yes, hard to get that top clip, very tight space up there. But with a long flat blade screw driver I did it. Took me maybe 20 minutes. And I'm 64, so no kid.
Keep at it and watch the videos of installation. I would bet if you could get the car up on a lift it would be a lot easier. And once in, I am a happy camper as I love this transmission/clutch combo.
BrianL is offline   Reply With Quote
Old 04-12-2018, 10:27 AM   #16
cmeJATT
cmeJATT's Avatar
Drives: SS-6-SPD
Not sure if you already did it ..
But to unclip it I used a long screw driver .. once it was removed .. I unclipped sensor that’s in front .. remove the trans cooler liner zip tie and was able to get my hand in there .. or like others suggested find someone with small hands ����
cmeJATT is offline   Reply With Quote
Old 04-12-2018, 02:44 PM   #17
CPM
Drives: Black 2018 SS 1LE
Originally Posted by pbm6gto View Post
Turn it a little bit more (RPM's) and it eliminates the skip shift. I bet I've had it pop up 3 times in a year. Not an issue for my driving style.
Yeah, I can usually avoid it, but when it happens it just really steams me. Had it happen to me in stop-and-go traffic the other day and as soon as I got home I ordered the eliminator.
CPM is offline   Reply With Quote
Old 04-12-2018, 05:54 PM   #18
Colormegone
Drives: 2018 ZL1 1LE
Originally Posted by lugs View Post
Long screwdriver
This^
I bought the skip-shift wire kit on Amazon 13.95 shipped
Had my ZL1LE on the lift( which really really helps) one long flat head screw driver, 10 minutes later..done...
Mine still shows the skip-shift in the dash but it shifts to second gear at any rpm, works perfectly and I like that.
Colormegone is offline   Reply With Quote
Old 04-12-2018, 06:37 PM   #19
nearwater
nearwater's Avatar
Drives: '17 2SS 50th
Yup, super long screw drivers worked for me also.
Taped the dummy plug onto the screw driver to plug it into the transmission.
A lot of cussing too..
Was lying on the garage floor for about 10-15 min before getting everything done.
Try to be creative with various tools. You’ll be just fine.
'17 2SS 50th Anniversary | M6 | MRC | NPP | Nav | Sunroof | Black bowtie | GM dark tail
nearwater is offline   Reply With Quote
Old 04-12-2018, 07:41 PM   #20
mikeyg36
Drives: 2015 Z/28 #533
Originally Posted by Childs Play View Post
Nope. Shouldn't be. But I'm sure GM would also figure out a way to screw you out of your warranty at that point. Depends on if you want to possibly void your warranty over a skip shift, or just install that one part. Although... They could probably figure out how to screw you over for that as well if they really wanted to be assholes.
Tuning for any reason will void your warranty. SSE is the better option unless you plan on doing other mods.
mikeyg36 is offline   Reply With Quote
Old 04-14-2018, 02:28 PM   #21
CPM
So does the clip on the white/blue piece face up in everyone else’s car, or am I just unlucky? I can’t figure out how the heck to get to that clip because it’s on the top side of that plug.
Old 04-16-2018, 08:04 PM   #22
CPM
Bump.
Old 04-16-2018, 08:29 PM   #23
Lerch98
Lerch98's Avatar
Drives: 2017 2SS black on black on black.
More right pedal and this never becomes an issue.
Lerch98 is offline   Reply With Quote
Old 04-16-2018, 09:18 PM   #24
Weege
Weege's Avatar
Drives: 2017 2SS convertible M6, NPP, MRC
No point reviving the old debate over the merits of the skip shift eliminator. Some us of thinks it's a godsend, others a non-issue. More annoying than an expected forced 1-4 shift is literally having the solution in hand but not being able to install it. There are several helpful videos on YouTube. Here's a link and a screenshot from one.
https://youtu.be/tYaV1R841vs
Did you hear about the restaurant on the moon?
Great food
No atmosphere.
Weege is offline   Reply With Quote
Old 04-17-2018, 06:57 AM   #25
CPM
See, that guy’s plug has the clip facing downward, which would make things considerably simpler. That’s on an SS, though, not a Camaro. Do your Camaros have the clip facing up (like mine) or down (like this guy’s SS)?
Old 04-17-2018, 08:15 AM   #26
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Do you just ram the car in front of you that's causing this, or go around them in oncoming traffic?
Old 04-17-2018, 10:45 AM   #27
Techn9cian805
The BEAST
Techn9cian805's Avatar
Drives: '16 2SS, '89 Wife
A long screwdriver is essential. It's not easy, but its doable.
semi-related, i saw someone on instagram who installed the skip shit eliminator with ease, and he was pretty proud of how easily he installed it...
however, he installed the skip shift on the part that controls the reverse lockout solenoid in the rear, which is easey to access lol, not the skip-shift one...
Scarlet: 3/3/16: 2SS Red Hot, M6,
Instagram: @luis_what_it_is
Techn9cian805 is offline   Reply With Quote
Old 04-17-2018, 11:26 AM   #28
Weege
Weege's Avatar
Very sorry, not the first time I thought SS meant Camaro SS. Hope you get the help you need. Can't imagine things come from the factory any differently between Camaros of the same model year with regard to plug/clip configuration.
Great food
No atmosphere.
