Old 05-15-2021, 07:51 PM   #113
TrackClub
TrackClub's Avatar
Originally Posted by WhiteMale View Post
Done...good pics here and ive done this type before...easy.
Great to hear! Hope my car will be out of storage soon for a full service: fluids, brake pads and tires. Cheers!
Old 05-02-2022, 09:18 AM   #114
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
I went ahead and made a quick video on the diff fluid change:
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21
2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 08-01-2022, 11:20 AM   #115
paradigm
Drives: 2022 Camaro 1SS 1LE
Which fluid are you guys going with in the eLSD?
Are you jacking up both the front and back evenly or just the rear?
Are you jacking up under the rear differential?
2022 Camaro 1SS 1LE 6-speed
paradigm is offline   Reply With Quote
Old 08-01-2022, 12:15 PM   #116
FollowMyLine
Driver for Hire
AC Delco Diff Fluid
Use the AC Delco stuff. It has the proper blend of added friction modifier. I raise the front and rear of the car equally, but if you want you can raise the front a tiny bit higher as the plug is at the back.
Luan Zeqollari
YouTube Channel
Old 08-03-2022, 08:41 AM   #117
paradigm
Should I be changing this fluid at 1500 miles? The car is not track driven.
Dealer says to wait till 45000 miles, lol.
Old 08-03-2022, 10:09 AM   #118
FollowMyLine
Driver for Hire
Technically, the dealer is correct. I would still change the original fluid at 1,500 even if you don't plan to track it. It'll help get all the assembly lube and minor metal shavings out. Get the fresh fluid in there and then leave it until 45k.
Luan Zeqollari
YouTube Channel
Old 08-17-2022, 04:49 PM   #119
paradigm
I ended up changing the fluid today at 3089 miles. The fluid came out black, and the drain plug had a lot of material on it:
Before:
After:
Old 08-17-2022, 04:53 PM   #120
FollowMyLine
Driver for Hire
That is pretty normal for the first and second change. Nothing to worry about.
Luan Zeqollari
YouTube Channel
Old 10-18-2022, 10:37 PM   #121
POWERFULMOVES
Drives: 2022 2SS 1LE MT
im somewhat confused when I go to amazon it says use ACDelco GM Original Equipment 10-4016 GL-5 75W-90 Synthetic Axle Lubricant - but I usually see to use ACDelco GM Original Equipment 10-4034 Dexron LS 75W-90 Gear Oil - 32 oz
which one is it? I have a 2022 2ss le and i want to change the fluid
POWERFULMOVES is offline   Reply With Quote
Old 10-18-2022, 10:52 PM   #122
FollowMyLine
Driver for Hire
This is the correct fluid:
ACDelco 10-4034 PN: 88862624
Amazon usually has no clue which parts “fit” for our vehicles.
Luan Zeqollari
YouTube Channel
Old 10-19-2022, 03:52 AM   #123
POWERFULMOVES
if i used the other one mentioned (ACDelco GM Original Equipment 10-4016 GL-5 75W-90 Synthetic Axle Lubricant - 1 qt)
would it mess up my differential?
Old 10-19-2022, 07:28 AM   #124
FollowMyLine
Driver for Hire
That all depends. It won’t mess anything up, as long as you add the friction modifier to the differential as well. ACDelco Friction Modifier
I just wouldn’t run it long term. The correct fluid has the proper ratio of friction modifier already mixed in.
Luan Zeqollari
YouTube Channel
Old 03-27-2023, 03:00 PM   #125
eldersCAMARO
CamaroLove
Drives: 2023 ZL1 Shark Skin
question
is this the correct fluid for the 23 ZL1 as well?
eldersCAMARO is offline   Reply With Quote
Old 03-27-2023, 03:19 PM   #126
FollowMyLine
Driver for Hire
Yes, it sure is!
Luan Zeqollari
YouTube Channel
