04-06-2016, 10:20 AM | #1 |
RPI Designs 2016 Camaro 6th Generation Splash Guards - Stealth
2016 6th Generation Camaro Stealth Splash Guard Kit - Mud Flaps / Mud Guards
(Patent Pending Design) This 2016 Camaro splash guards kit includes four splash guards, two for the front wheels, two for the rear wheels. No drilling, glue or tape required. These 6th Generation Camaro splash guards use stock hole locations to mount in combination with provide clips. You can even install these without removing your wheels! A great way to help protect the side of the car from stones and debris and be indiscreet about it!! We also offer these splash guards in a thicker premium plastic that is nearly twice as thick as our regular splash guards for the ultimate in durability. Please select that option when making your purchase. 6th Generation Camaro Splash Guards / Mud Guards Installation: •The 2 front splash guards require the removal and re-installation of 1 push style pin per splash guard. We also include one "U" clip to secure the top of the flap. Installation is much easier if you turn your wheel to allow you to easily access the push style pin. Simply remove the pin with a flat screwdriver. You'll see a small notch in the pin, use the screwdriver to pop that loose. Then pull the rest of the pin out. The pin is actually a two piece unit. •Now place the splash guard into position, push the large part of the pin through the hole in the plash guard until flush with the fender liner. •Next take the rest of the pin and tap it into the large part of the pin which is now installed in your Camaro fender well. •Lastly, take one of the two “U” clips and install it near the top of the splash guard, burr to the back of the fender lip. •The 2 rear splash guards include new bolts that are slightly longer to accommodate the splash guard. •You'll remove the two bolts shown in the picture above and install the new bolts in their place. Use the provided Torx head wrench to remove the two bolts. •Put in the new bolts and tighten with a standard socket. Do not overtighten. •The rear splash guards have a block built into them to push them 1/4" away from the fender liner to create a sleek appearance. These splash guards (mud flaps) are made for the 2016 Camaro, they are not a universal splash guard kit. These were designed to follow the body lines of the Camaro and to remain almost un-seen. All hardware is included along with the proper screwdriver for a very simple installation. These Camaro splash guards / mud guards are also available pre-painted to match your Camaro. Please email us for more information. Item # CAM202 use coupon code LANA5 on line or by phone when ordering and save 5% off the listed website price!!! Website Link : http://www.rpidesigns.com/shop/item....rds---stealth/ Last edited by RPIDon; 10-05-2017 at 12:31 PM. |
05-19-2016, 01:42 PM | #2 |
Recieved and installed. Took only 5 minutes. Love the product
05-19-2016, 02:17 PM | #3 | |
05-19-2016, 03:37 PM | #4 |
Drives: 2016 Camaro 2SS 6M Nightfall Gray Join Date: May 2016
Got my set in yesterday. Super easy install and seem to be doing their job so far. They look pretty good too.
05-27-2016, 11:55 AM | #5 |
Drives: 2017 RS convertible Join Date: May 2009
I had these on both my 5th gens. installed them for someone on her 5th gen as well. they definitely saved me from some chipping. when I get my next car, they're going on that one as well.
Camaros I've owned:
1969 RS/SS Z10 Indy Pace Car - Hardtop 1 of 250 1970 Camaro 2010 2LT RS 2013 2SS RS Current ride: 2017 Camaro 2LT RS convertible |
06-03-2016, 01:08 PM | #6 | |
07-20-2016, 01:11 PM | #7 |
A great and easy way to help protect the paint on your camaro and use coupon code RPIDON5 on line or by phone when ordering and save 5% off the listed website price!!!
08-17-2016, 10:29 AM | #8 |
Drives: 2017 2SS - MRC, NPP, M6 Join Date: Jun 2016
Does anyone have pictures of these installed on a 2016 from the front or front 3/4 view?
08-22-2016, 12:36 PM | #9 |
Drives: 50th 2LT RS Join Date: Aug 2016
Would love to order these ASAP! Any reason they would not fit a 2017 50th Anniversary edition?
Thanks! Mike |
08-29-2016, 09:55 AM | #10 |
Drives: 2016 SS 6 Spd Join Date: Jul 2009
10-03-2016, 08:11 AM | #11 |
Easy way to protect your car's paint.
12-01-2016, 10:27 AM | #12 |
Software Architect
Drives: 2017 Camaro 2.0L Turbo Join Date: Nov 2016
Going to be buying one soon as well since the weather is starting to get bad here. Quick question: what's the difference if I buy the normal one and the premium splash guards?
12-02-2016, 07:48 AM | #13 |
The premium splash guards are just thicker than the regular version. Both work equally well. The thinner splash guards are a little easier to install because they are more flexible. But that is the only real difference.
12-21-2016, 10:01 AM | #14 |
(Patent Pending Design) This 2016 Camaro splash guards kit includes four splash guards, two for the front wheels, two for the rear wheels. No drilling, glue or tape required. These 6th Generation Camaro splash guards use stock hole locations to mount in combination with provided clips. You can even install these without removing your wheels! A great way to help protect the side of the car from stones and debris and be indiscreet about it!! We also offer these splash guards in a thicker premium plastic that is nearly twice as thick as our regular splash guards for the ultimate in durability. Please select that option when making your purchase. 6th Generation Camaro Splash Guards / Mud Guards Installation: •The 2 front splash guards require the removal and re-installation of 1 push style pin per splash guard. We also include one "U" clip to secure the top of the flap. Installation is much easier if you turn your wheel to allow you to easily access the push style pin. Simply remove the pin with a flat screwdriver. You'll see a small notch in the pin, use the screwdriver to pop that loose. Then pull the rest of the pin out. The pin is actually a two piece unit. •Now place the splash guard into position, push the large part of the pin through the hole in the splash guard until flush with the fender liner. •Next, take the rest of the pin and tap it into the large part of the pin which is now installed in your Camaro fender well. •Lastly, take one of the two “U” clips and install it near the top of the splash guard, burr to the back of the fender lip. •The 2 rear splash guards include new bolts that are slightly longer to accommodate the splash guard. •You'll remove the two bolts shown in the picture above and install the new bolts in their place. Use the provided Torx head wrench to remove the two bolts. •Put in the new bolts and tighten with a standard socket. Do not overtighten. •The rear splash guards have a block built into them to push them 1/4" away from the fender liner to create a sleek appearance. These splash guards (mud flaps) are made for the 2016 Camaro, they are not a universal splash guard kit. These were designed to follow the body lines of the Camaro and to remain almost unseen. All hardware is included along with the proper screwdriver for a very simple installation. These Camaro splash guards/mud guards are also available pre-painted to match your Camaro. Please email us for more information. Item # CAM202 use coupon code PHIL5 on line or by phone when ordering and save 5% off the listed website price!!! Website Link : http://www.rpidesigns.com/shop/item....rds---stealth/ Last edited by RPI Designs; 08-28-2017 at 01:46 PM. |
