04-18-2019, 07:58 PM | #29 | |
Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
My FM has a slight buzz to them but nothing like the stock rattle. Perhaps over time they will deteriorate to shit as well. For now they just sort of hum, which I can only hear when I'm standing in the back or when the windows are down in a garage, but it is faint. The stock was noticeable on the highway, windows up, over all of the road noise. |
04-19-2019, 03:54 PM | #30 |
Drives: Nightfall Gray LS 1LE Join Date: Sep 2018
My dealer tried the Epoxy fix, didn't work. Advised they are ordering and replacing exhaust.
04-22-2019, 06:11 PM | #31 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I used a Dremel to clean the dealer applied epoxy all around the ceramic pin this weekend. I mixed up some more quick setting epoxy, closed the valves and put some on and then opened them and put some on the other side of the valve. So far so good, I can't detect a rattle anymore. I also previously took out the AFM valves also, but they appear like they were never the problem. I think its critical that whoever applies the epoxy needs to make sure the surface is properly cleaned, also most epoxy require the surface to be sanded or roughened up before it is applied.
04-23-2019, 11:00 AM | #32 | |
Drives: 2018 2ss 1le Join Date: Jan 2018
do you have any pics?
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned |
04-29-2019, 05:38 AM | #33 |
bump
05-01-2019, 05:44 PM | #34 |
So I don't have any pictures, it did clean it up nicely. But unfortunately the rattle is now back again, I guess I will clean it off again and try a different epoxy, or I may try high temperature RTV silicone just to see what happeneds. Yeah I don't think it will work, but I don't have anything else I know I can do.
05-01-2019, 09:45 PM | #35 | |
I respect your efforts to chase this down, but I'm unfortunately going to revert to what I said before. There's no fixing this. However, I'd push this to Chevy to get it figured out now that they are well into production. They have to fix this, but it will require a lot of your effort and time. Or you could just punt and buy something aftermarket, which is also a crap shoot given the current offerings. |
05-02-2019, 05:53 PM | #36 |
I've already got over 70k on mine now, so I wouldn't think they would listen being out of warranty. Now I did use just some random epoxy laying around, not the Loctite fixmaster that is in the TSB.
05-09-2019, 02:43 PM | #37 |
FASTER!
Drives: Challenger Hellcat, 2SS Camaro Join Date: Apr 2008
Is this still a problem with 2018 and 2019 vehicles with NPP? I thought surely GM would have updated their system by now. My 2016 2SS with NPP rattles and has been epoxied twice. I'm going to ask for a replacement exhaust next trip to the dealer for this.
For comparison, my Hellcat has a similar exhaust system that does NOT rattle. |
05-09-2019, 06:10 PM | #38 |
are there aftermarket valves than can be purchased that don't rattle?
05-09-2019, 07:53 PM | #39 |
Borla
05-09-2019, 07:59 PM | #40 |
FASTER!
So we pay about $900 for upgraded npp exhaust and the forum recommendation is to spend more on aftermarket exhaust?
05-09-2019, 08:14 PM | #41 |
FASTER!
Guess GM can buy it back.
05-11-2019, 12:15 AM | #42 |
