02-15-2021, 11:31 AM | #1 |
Searching for my 6th Gen
Drives: In The Market Join Date: Mar 2020
non NPP aftermarket exhaust - convertible
Do any of you with convertibles and non NPP have an exhaust cutout system you like? I had a 98 Z28 that had the cutouts and I loved them. I wanted to do the same on my new car, but every one I find says it wont fit a convertible?
thanks |
02-16-2021, 07:22 AM | #2 |
Hot Camaro
The convertibles have extra bracing under the car that interferes with pretty much any of the aftermarket pipes between the cats and the muffler(s) - that's why you're finding what you are...
02-16-2021, 10:52 AM | #3 |
Drives: 2021 Camaro LT1 Conv Join Date: Oct 2016
I didn’t go with cutouts but this would apply to you also. Your only option is to purchase a universal cutout and goto an exhaust shop that does custom work. I wanted to remove the secondary cats and replace all the piping from the main cats back with 3” piping for sound reasons but also so I would be ready for headers at a later date.
I bought the 3” x-pipe kit below for $200 even though they clearly state it won’t fit convertibles and the exhaust shop I went to was able to weld it all in place without removing or modification to the bracing. It was definitely not a plug in play job, modifications to the piping from the kit had to be made, but it wasn’t a job a more reputable exhaust shop couldn’t handle. https://wildhammermotorsports.com/16...ed-engineering |
02-16-2021, 05:24 PM | #4 |
Drives: 2016 SS Convertible Join Date: Sep 2016
most cat-backs fit the way they come - even if they claim they will not. I don't think most companies bother checking on a Convertible. I have a MagnaFlow cat-back kit and there were no issues installed on a convertible at all.
02-16-2021, 10:15 PM | #5 |
So after reading these, I Looked under my car at the exhaust - the factory exhaust is squished almost in half where the added x members are for the convertible! Is that normal?!
02-16-2021, 10:22 PM | #6 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
02-16-2021, 10:35 PM | #7 |
Interesting!
02-17-2021, 11:56 AM | #8 |
That is correct. There’s very little room underneath the convertibles but as I learned, just barely enough where you can go the custom route/modifying an aftermarket kit without any major impediments.
02-17-2021, 11:58 AM | #9 |
The cat back kits connect behind that squished section, so there really isn't any difference in fitment coupe vs. vert.
02-17-2021, 01:25 PM | #10 |
Try the AWE Touring non NPP axel back. That is what I went with and love it
02-18-2021, 10:49 AM | #11 |
Drives: 2019 Camaro 2SS Vert Join Date: Apr 2020
So after reading this thread, I had a Borla axle back exhaust installed when I purchased my car (was told cat back was not available), can I purchase the 3" X-Pipe and call it good?
02-18-2021, 10:53 AM | #12 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
just note, swapping a resonated "x" pipe for a non-resonated true-x has been known to introduce rasp in certain muffler combinations.
Not a big deal if it does, you just go back and have them use a resonated one (they're more expensive) ...but yea. |
02-27-2021, 09:14 AM | #13 |
What does adding the x pipe do?
02-27-2021, 11:04 AM | #14 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
Basically X/ H-pipes allow opposing exhaust pulses more volume to move in. Think of it as a car pool lane during rush hour. There can also be a scavenging effect.
Aside from the firing order differences, this pretty much explains it. http://www.superchevy.com/how-to/exh...-for-your-ride |
