Old 05-01-2017, 02:04 PM   #29
MTS2020
MTS2020's Avatar
Drives: 2017 HBM SS 1LE
Sean do you mind taking a straight no angle side shot of you car with that wicker on? I'm loving that thing
2017 SS 1LE Hyper Blue Metallic
2016 Yukon SLT White Frost Tricoat
2012 Maxima SV Sport Winter Frost Pearl
MTS2020 is offline   Reply With Quote
Old 05-22-2019, 08:27 AM   #30
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
*Reviving an old thread*
Anyone got close up shots of the bolts? I bought a used one need to purchase the rivnuts also notice these bolts are silver and on the picture all I see are black
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
G2K is offline   Reply With Quote
Old 05-22-2019, 10:12 AM   #31
Vaider
Drives: 18 NFG 1SS 1LE
To the OP, nice ride. Which tail lights do you have? They look great with the Nightfall Gray.
Vaider is offline   Reply With Quote
Old 05-22-2019, 09:27 PM   #32
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
GM Wickerbill Installed Photos
Sent from my iPad using Tapatalk Pro
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 05-25-2019, 07:46 AM   #33
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
Drives: 2018 1SS 1LE
I guess I'm the odd one out. All I see is a spoiler bolted to a spoiler.
2018 1SS 1LE
GTSLOW is offline   Reply With Quote
Old 05-25-2019, 06:05 PM   #34
z28pat
z28pat's Avatar
Drives: 2002 z28, 2018 2ss 1LE
Glad I’m not the only one who doesn’t like it , to each their own and the beauty of owning the car is that you can do whatever looks good to you.
To me it seems like an afterthought piece after all the performance they got out of the 1le from great parts (mrc, brakes, wheel/tire combo, seats, elsd )
z28pat is offline   Reply With Quote
Old 05-25-2019, 11:35 PM   #35
Tim M
Drives: 2018 Camaro SS 1LE
Like or not, great that Chevy offers an actual aero part - Gurney flap that provides significant down-force (relatively) without much increase in drag.
I might buy one just to have...wonder how much it would reduce top-speed.
Tim M is offline   Reply With Quote
Old 05-28-2019, 10:49 AM   #36
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Thanks for the pic, is this an OEM one? or one of the ZL1addons site?
I also noticed this is an allen type bolt...
Old 05-28-2019, 04:02 PM   #37
Ryanbabz71
Ryanbabz71's Avatar
The GM accessory.
Ryan
Old 05-30-2019, 05:39 PM   #38
Warrior102
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
A modern version of let's just bolt this here...
Warrior102 is offline   Reply With Quote
Old 05-31-2019, 07:16 AM   #39
Gen6_1Le
Gen6_1Le's Avatar
Drives: 2018 Camaro 1Le
That's about all it is , yet can do so much for a car .
I added a video on how it became to be .
Gen6_1Le is offline   Reply With Quote
Old 02-23-2021, 01:28 PM   #40
SloCal
SloCal's Avatar
Originally Posted by RUQWIKR View Post
After having the wickerbill sitting in the shop for a few months, I finally installed it Monday and took pics today. With multiple car projects, kids, family items, work, etc., I'm a bit slow at times. I do think it is BY FAR, in my opinion, the best looking vs. the aftermarket ones seen so far.
As far as what it does to the balance with added downforce without more front splitter to offset, I'm going to do some experimenting.
The ride height sensors have a voltage range when key on of 0.25 to 4.75V, the higher the lower the ride height. One of these days, I'll make a run on smooth road at a given (high) speed and get readings from the front and rear with and without the wickerbill on. I can see what it does to the ride height trims at speed. You could do the same with another car with a different wickerbill / splitter set up to compare.
I'll also take some readings at full jounce and rebound to get the ride height to voltages for each corner. May take a while to do this due to my work and home schedule, but, it will be good to know. Any of that will be skewed by current vehicle weight (fuel load, junk in the trunk, etc.).
Did you ever do testing on this?
2018 1LE
2nd 6th gen
SPL Toe Arms/Brembo HTC64t/Corsa NPP/Tremec MTF Fluid
SloCal is offline   Reply With Quote
Old 02-23-2021, 04:33 PM   #41
NeverDie
Drives: 2017 Camaro SS 1LE
Looks like landscape edging to me
NeverDie is offline   Reply With Quote
Old 02-23-2021, 10:41 PM   #42
Wvdirtroads
Drives: Silverado
Will this fit on a 2019?
Wvdirtroads is offline   Reply With Quote
