TireRack
Old 08-17-2009, 04:28 PM   #15
toehead93
Drives: 2014 2SS/1LE
Originally Posted by irpq11 View Post
STD, SAE
Are my numbers actually lower or what?
No, SAE corrected will increase the numbers unless you're below sea level and somewhere really cold and dry.
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 08-18-2009, 03:37 PM   #16
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Oh, SNAP. You mean if it were run with SAE it would have been HIGHER than the 317 recorded?
I'm confused. I should be running faster.
Delete if needed.
Old 08-18-2009, 09:26 PM   #17
O2BQIK
Drives: 1991 Camaro RS
Probably. SAE-corrected does take into account temperature and humidity to theoretically provide a standardized number. Given you dyno'd in the south and in the summer, it's likely that if it were SAE-corrected it would be a higher number.
2010 Camaro SS in black/beige: Sold. | '91 Camaro RS: Still the dream car!
'98 Camaro SS: Incon twin turbo. Sold | '99 Camaro SS: Heads/cam/bolt-ons. Sold.
O2BQIK is offline   Reply With Quote
Old 08-19-2009, 06:20 AM   #18
acatlover13
Emerald Coast Camaros
acatlover13's Avatar
Drives: 2010 2SS/RS Camaro IOM/IO
Send a message via AIM to acatlover13 Send a message via Skype™ to acatlover13
Two questions...does anyone know somewhere in NW FL I can go to dyno my car, and what tuners are you guys using? Someone mentioned a Diablo Sport, but what else? Thanks guys!!
acatlover13 is offline   Reply With Quote
Old 08-22-2009, 04:13 PM   #19
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
If you can drive to Tampa, Jeremy Formato is a great tuner. He is very respected in the LSX community.
www.fasterproms.net
He also visits different tuning shops in other area of Florida.
SGOS252382 is offline   Reply With Quote
Old 08-28-2009, 08:42 PM   #20
Sponge60
OBX
Sponge60's Avatar
Drives: 2010 2SS / RS, Black on Black, L99
Advertised 400 HP
How does GM get away with advertising the HP at 400 for the L99 and 426 for the LS3 when no one has dyno'd that? Did I miss something in the fine print?
Glenn Rainey
Outer Banks, North Carolina
Sponge60 is offline   Reply With Quote
Old 08-28-2009, 09:55 PM   #21
BB_Yellow2010
BB_Yellow2010's Avatar
Drives: 2010 2SS RS L99 Rally Yellow
These Dyno's calculate RWHP (rear wheel Horse power) Chevy calculates Horse Power at the crank.
This car is amazing...
BB_Yellow2010 is offline   Reply With Quote
Old 08-28-2009, 10:06 PM   #22
rodimus prime
Drives: Cargo van.
Might as well post mine here.
First run is stock at about 700 miles.
Second run is with rotofab cai and a tune done about two weeks later.
rodimus prime is offline   Reply With Quote
Old 08-30-2009, 07:12 PM   #23
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Because despite what Top Gear tried to promote in their dyno test of a GT500, the number that is advertised is not the same as what you will be testing when you strap it down for a dyno run. GM and every single other automaker out there rates their engines with an engine dyno. This is a test rig that measures the output of the engine. A chassis dyno, which is what you most often see, measures the power at the wheels. This is the power at the crank minus any losses from the drivetrain.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 08-31-2009, 09:28 AM   #24
Sponge60
OBX
Sponge60's Avatar
Thanks guys. I better understand the process now. Great explanations!
Glenn Rainey
Old 09-03-2009, 10:20 PM   #25
thebrainhart
thebrainhart's Avatar
Drives: '10 Camaro 2SS/RS CGM LS3 A6
Just dyno'd mine tonight, complete stock to the filter, 1050 miles, easy first 450, then having fun. Pulled fuses at about 600 miles.
About 85 degrees, first run 321hp, 336tq. Second run (about 1 minute idling rest) 313hp, 319tq
- 2010 Camaro 2SS/RS CGM LS3 A6 "Lurch" - FLYNGSS -
Some ProCharger, Alky, CompCams, Brian Tooley, Holley, Livernois, K&N, Ridetech, DSS, Kooks, JDP Motorsports, Pfadt, BMR, Prothane, Weld, M&H, Mickey Thompson, RKSport, Elite, Garys, Defenderworx, Anvil, etc.
thebrainhart is offline   Reply With Quote
Old 09-05-2009, 03:19 PM   #26
SGOS252382
SGOS252382's Avatar
Your torque takes a major nose dive around 3500 rpms?
Old 09-10-2009, 11:23 AM   #27
skisax80
Drives: 2010 camaro ss/rs
how can so many stock L99s have some any different readings? i mean i know temp humidty things of that nature affect it, but i didnt realize it was that much...
skisax80 is offline   Reply With Quote
Old 09-17-2009, 03:28 PM   #28
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
You have to remember that there are Mustang Dyno's which add a load to the drums where the rear wheels are turning and the load is based on the weight and Co efficient drag of the car being tested. A dyno jet doesn't really have that kind of load and is calibrated differently. Just remember that not all dyno's are the same. Just use it to get your tuning down and take it to the TRACK!!
litle88 is offline   Reply With Quote
L99 Love Mod4SS 5th Gen Camaro SS LS LT General Discussions 95 02-14-2015 07:51 PM
Dyno Dynamics AWD Dyno @ Hennessey Performance Hennessey Performance USA - Texas 0 08-08-2009 10:03 AM
LS3 Tune Only Results .. Also stock LS3 vs. L99 dyno graph LPFSTheFett Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-05-2009 07:04 AM
Tuning LS3 vs L99 Evilangel Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 10-30-2008 10:22 AM
L99 engine specifications Tran Wiki 0 10-19-2008 11:40 AM
