03-21-2023, 09:35 AM | #29 | |||
Shadow Gray '19 ZLE M6
You're about 45 mins from me -- I'm in Summit. If you'd like, you're welcome to come by and I will help you with the install. We can toss your car up on my quickjack. It'll be a 5 min install -- more time will be spent getting the car in the air than installing the skip shift eliminator. Let me know.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
03-21-2023, 10:15 AM | #30 |
Drives: 2023 Camaro ZL1 Join Date: Feb 2023
Which one I should get? What are the options?
03-21-2023, 10:27 AM | #31 |
Honestly, get the cheapest one you can find. Here are some options...
https://www.ebay.com/itm/143201828613 https://www.phastekperformance.com/p...aro-v8-manual/ https://www.amazon.com/Muzzys-Camaro.../dp/B00J6DJOPE
03-21-2023, 10:52 AM | #32 |
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
To the OP these transmissions an be kind of notchy. When you shift from 1st to second make sure to do it firmly. It’s almost like a 2 part feel to it. And don’t worry about buying and installing a skip shift eliminator. Just give it a bit more gas and shift at 18 mph+. My car only did that once and it was my fault. It was cold out and I was going too easy on the pull from first to second. Make sure you feel it stop when you pull the shifter down. Good luck.
03-21-2023, 10:56 AM | #33 |
Thanks! Looks like some of them have wiring between two harnesses, some don't. Is there a difference?
03-21-2023, 11:09 AM | #34 |
No difference.
03-21-2023, 01:23 PM | #35 | |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
I’ve owned a manual Camaro since 2012 and maybe had skip shift pop up six times in those 11 years so I’ve never seen it as a big issue. I’m almost always above 20 mph when I shift from 1st to 2nd.
