03-18-2023, 07:47 AM | #15 |
Drives: 21 Lt1 Join Date: Dec 2016
I received mine today. I already had the t87 swap but got the t93 to play with. Hp tuners claims there are tables that can’t be seen with the t87 that the t93 has. I’m planning on swapping them out shortly and reading it.
21 Camaro LT1 Fully forged, Katech ported stock heads, P1X,3.7 upper and ATI w/ 8.25 lower, Stage 2 intercooler, Race B.O.V, Btr stage 2 blower cam, Btr Trinity intake, 103mm TB, F.I.C +30’s, Fore innovations, LPE big bore pump, Weld Lagunas Drag Pack. Circle D TC. Full Bmr upgrades, Keltrac rear shocks.
03-18-2023, 08:52 AM | #16 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
03-18-2023, 09:02 AM | #17 |
For sure. Maybe someone a little more knowledgeable like King or someone would have more knowledge looking at it but will gladly let you know if I notice any changes.
03-18-2023, 09:17 AM | #18 |
Good to hear, would love to know more when you figure it out. I wished I'd had mine overnighted instead of second day air. Tuesday thru Thursday looks like rain here so hopefully I'll get some dry time for some logs to figure things out since I have TNT on Saturday the 25th.
03-18-2023, 09:30 AM | #19 | |
I’ll update once I read the file etc.
03-18-2023, 09:48 AM | #20 |
Sounds good. Thx for chiming in on your T93 update.
03-18-2023, 04:09 PM | #21 |
You’re welcome.
Well as far as I can tell there are no differences except that my t87 tune won’t flash to the t93. All the tables look the same, it’s just like the t87 so it won’t let you read the file, it just gives you the stock file after you try to read it.
03-18-2023, 07:13 PM | #22 |
Explain, so since I didn't have a stock file to read before I'll just have to make changes to what ever it reads which your saying is just the file that GM had hidden that we couldn't change before it was unlocked. Correct?
03-18-2023, 07:26 PM | #23 | |
I’m having some problems thou: I copied everything over from my T87A to the T93 and it will not write. I’ve never had this issue before. It shows that it writes but the car says put in Park and will not do anything, I unhook battery and when I try to start it says put in park again. I’m not sure what’s going on. I was able to write the stock file I read from it thou so idk what’s causing the issue.
03-18-2023, 07:44 PM | #24 |
Petro-sexual
Did you plug the T93 in correctly? That plug can be turned 180* and plug in. I had similar problems when I first plugged the T87 in. I didn’t even know I did it. Chuck at HHP told me to reverse the plug and BINGO.
03-18-2023, 07:50 PM | #25 | |
It allows me to flash the stock file but it’s not allowing the tuned file. Idk
03-18-2023, 08:12 PM | #26 | |
You definitely wouldn’t be able to use the T87A file at all since it’ll have a different OS. But no reason you couldn’t do a “compare file” and copy changes to the T93 file.
03-18-2023, 08:15 PM | #27 |
Yes exactly. I compared and copied everything over. What’s weird is I can flash the stock T93 file but the copied file won’t. I’ve triple checked the file idk what else it could be.
03-18-2023, 11:21 PM | #28 |
So you can't modify the T93 TCM you sent in and had unlocked? You can't up the shift pressures? Change the torque levels from stock? Maybe I'm misunderstanding what your saying.
