12-06-2022, 06:29 PM | #1 |
Drives: 2017 Camaro Zl1 Join Date: May 2022
Obd2 Ethanol Reader Problem
Hello Guys So Ive Read Here In A Couple Of Old Threats That It Is Possible To Read Your Ethanol Content With A Couple Apps Like Torque Pro Or Obd Fusion. Ive Been Trying This With My Old Android And My Iphone And Cant Get It To Work. I Read That You Have To Make A Custom Pid I Tried That And Nothing Seems To Work. Does Anyone Know What The Problem Is Or If Im Possibly Doing Something Wrong? I Am Copying The Same Equation And Nothing Seems To Work. If Someone Can Please Walk Me Thru This Let Me Know.
2017 Zl1 6speed Intake Headers Flex Fuel Tune |
01-12-2023, 08:07 PM | #2 |
NOXQCES ZL1
Drives: 2017 Camaro ZL1 Join Date: Mar 2019
Thank You for postíng this question, Im struggling with exactly the same issue using TorquePro and a ScanTool OBD device.
Thanks to anyone who chimes in to help! |
03-10-2023, 07:31 AM | #3 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Have you guys cracked the code on reading ethanol percentage on the Torque app? Around five years ago, I created a custom pid in the Torque app on my Samsung Galaxy S7. King LT1 coached me on the process, and it worked like a charm. Shortly afterwards, I upgraded to a Samsung Galaxy S10. I followed the exact same procedure to add a custom pid for ethanol, but could never get it to work. I have worked around this by keeping the old S7 in the car for the sole purpose of monitoring ethanol content. This is a minor pita as I have to remember to keep the phone charged.
I upgraded to a Galaxy s23 the other day and decided to try my luck on the new phone. I was not successful. The process for adding the alcohol pid is definitely not 100% identical between phones. I know I am using the correct pid# and equation. I even deleted and re-added the pid on the old S7 just to verify that I wasn't doing something wrong. The re-added pid worked just fine.
Baby Blue
03-10-2023, 10:01 AM | #4 |
Might be a compatibility issue with Torque pro software version and Samsung firmware version. You might try emailing Torque pro and see if they can update the app. All of my Pixel phones seem to work fine with it. I am currently using a 5a on Android 13.
2016 NFG 1SS A8
03-11-2023, 08:24 AM | #5 |
Good idea, King. I reached out to Torque pro.
Baby Blue
03-14-2023, 10:05 AM | #6 |
Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
Last time I check mine was working. You have to do a user defined PID. Here are the settings I used.
And I'm not even using torque pro, just torque. |
03-14-2023, 10:08 AM | #7 |
03-14-2023, 05:59 PM | #8 |
We are well aware of that but thanks!
2016 NFG 1SS A8
