04-08-2020, 09:52 PM | #29 | |
My guess would be that they were designed for super quick replacement from their racing experience.
04-09-2020, 07:48 AM | #30 |
Not sure about the MRR017. but the MRR M228's which I have were the problem wheels with the valve stem hitting the "skate wheels". I just cut mine off!! Problem solved. A lot of folks have done this on here. I for one have never had any noise issue from my Brembos, ever, and still don't. 113k miles on her now.
04-11-2020, 11:06 AM | #31 |
Grumpy Grey-haired Guy
Drives: Camaro, Corvette & Merc C300(daily) Join Date: Aug 2014
They're added for harmonics ( to absorb and reduce noise) they may also act as a small heat-sink but as they're surface area is relatively small it probably ain't very effective.
04-11-2020, 03:16 PM | #32 | |
376 cubic inches of fun
At some point (don't know the model year), they were deleted from the brake design. |
04-12-2020, 06:23 AM | #33 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
They sell brake pads with and without the 'skates'... I've worn both.
Result? the Skates help noise vibration and work. I will not ever wear pads without them on this ride again. |
