Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 03-10-2023, 07:23 AM   #15
bsn
Drives: 2013 ZL1
If your performing oil changes as recommended by the manufacturer using a chaser oil to get the remaining oil out is a complete and total waste of money. The small amount of leftover oil will have ZERO impact on wear or engine life.
bsn is offline   Reply With Quote
Old 08-27-2023, 05:15 PM   #16
Rusty Shackleford
Drives: 2012 Camaro 2SS
I just put it on the shelf in the shop and use it on the next change. Seems like half my free time and money are spent changing oil.
Right now I have the C10 that uses VR1 10w30, Tractor using VR1 20w50, 1500 using syn 0w20, SS using 5w30, boat using yama-lube, OBS Suburban and XJ both using dino 10w30, and the wife has her Prius serviced at the shop.
My shop looks like a lube center. I dispose of oil 55gal at a time, lol.
Rusty Shackleford is offline   Reply With Quote
Old 08-27-2023, 05:29 PM   #17
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Wow! I just read through this thread. I can't believe someone is actually doing this!! And to "throw away" extra oil you didn't use?? WTF!! These oils we use today AIN'T cheap!! Yowza..
1JEWLDSSRS is offline   Reply With Quote
Old 08-28-2023, 09:20 AM   #18
Trickskier
Native Floridian
Trickskier's Avatar
Originally Posted by vinman View Post
I buy 2 5qt jugs of mobil 1 and after all the old oil is drained I pour about 1.5qts of clean stuff through before putting the plug back in so it grabs any gunk on the way down and out
I was told by a Mobil 1 tech to bring my engine up to operating temperature before draining the oil. This will suspend impurities in the oil and be flushed out when the drain plug is removed. Synthetic oil is to expensive to waste.
Old 08-28-2023, 07:01 PM   #19
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
This is what I've always done with all my cars to date. Just be careful of the hot oil!!
