dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 01-04-2023, 05:16 PM   #1
spyderbuddy
spyderbuddy's Avatar
Drives: 2010 RS Inferno Orange Metallic
For the 2010 to 2012 V6 Guys
Check your Radiator cap, if the gasket (O Ring) is flat change it.
Mine quit pulling the antifreeze back into the engine because no vacuum
almost cost me an overheated engine
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
spyderbuddy is offline   Reply With Quote
Old 01-05-2023, 02:26 PM   #2
Bigalamo
Bigalamo's Avatar
Drives: 2011 LS Camaro
Do you mean compared to a tubular gasket?
Good save!
Edit: thanks for uploading pictures.
Bigalamo is offline   Reply With Quote
Old 01-07-2023, 09:07 AM   #3
ForgotUsername
Drives: 2010 Camaro RS LT2
Totally agree, check your caps. Mine also had a seal that was flattened and there was a tear in the other seal, if i remember correctly. I was happy I saw it before anything leaked.
My car is 2010 v6 LLT, 140k miles and 10 years old at the time when I replaced the cap.
Looks like user 10camarodude had the same issue on this thread: link
ForgotUsername is offline   Reply With Quote
Old 07-15-2023, 08:06 AM   #4
GrandAmGT
GrandAmGT's Avatar
Drives: 2010 1LT & 2016 Cadillac CTS V6
Thank you so much for this tip!! I'm glad I randomly came across this thread. I ordered a new cap from Amazon and just installed it. The difference between the old cap and the new one was very obvious. The new cap even clicked into place differently after I fully screwed it in. I think more people need to be aware of this easy preventative maintenance.
GrandAmGT is offline   Reply With Quote
Old 07-15-2023, 01:25 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Great catch spyderbuddy!! And for posting..
1JEWLDSSRS is offline   Reply With Quote
Old 01-15-2024, 08:31 AM   #6
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
Interesting... Just checked mine and it is missing too but no coolant leak or overheating issues hmmmm....
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 01-15-2024, 01:01 PM   #7
SummitWhite11
Drives: 2010 2LT/RS
I went ahead and purchased a new AC Delco one from Amazon just to be on the safe side.
2010 2LT/RS
Old 01-16-2024, 08:30 AM   #8
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Drives: '69 Z/28 LeMans Blue w/White
Had to replace mine a few years ago on my SS. The O ring went flat.
Stingr69 is offline   Reply With Quote
Old 01-18-2024, 04:40 AM   #9
SummitWhite11
Drives: 2010 2LT/RS
Received my new radiator cap yesterday and while comparing the two, mine is actually flat as well rather than missing.
2010 2LT/RS
