05-12-2019, 05:56 PM | #1 |
Option list/ RPO codes
Where is this on a 2019 2SS?
05-12-2019, 06:12 PM | #2 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
Should be under the trunk false floor
05-12-2019, 06:13 PM | #3 |
05-12-2019, 09:49 PM | #4 |
Just saw your other thread about the empty space under the floor board in your trunk. Noticed you didn’t have the RPO sticker where it’s supposed to be located! Do you not have this sticker located anywhere in your trunk?
05-13-2019, 09:25 AM | #5 |
Drives: 50th Anniversary 2SS M6 Convertible Join Date: May 2015
RPO tags are becoming a thing of the past. Being replaced by QR codes typically on the door jamb. Most bar code scanner apps will decode.
2017 2SS M6 H50 Convertible 1 of 158
1100 8/05/16 | 2000 8/08/16 3000 8/10/16 | TPW 9/5/16 8/13/16 3100 8/26/16 | 3300 8/30/16 3400 8/31/16 | 3800 9/8/16 PS#2293 4B00 9/10/16 | 4200 9/13/16 5000 & 6000 9/14/16 |
05-13-2019, 09:29 AM | #6 |
Drives: '19 2SS M6. Join Date: Aug 2018
My 2019 does not have that rpo sticker.
Dealer printed out the entire list from my vin.
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
05-13-2019, 11:12 AM | #7 |
Drives: 2019 Crush Camaro Join Date: Mar 2019
Scan the QR square on the driver side door jam to get your RPO list. You'll need a QR scanner app. I used my cell phone.
05-14-2019, 09:10 AM | #8 |
I got the rpo codes from the qr. Thanks for that.
But, after looking at the list of rpo codes, the F55code for magnetic ride is not there. The window sticker says mag ride is there as an option. What's going on? |
05-14-2019, 11:10 AM | #9 |
Drives: 2017 1SS camaro ,2SS a 68 + 08 C6 Join Date: Dec 2017
Its possible magnetic code for the rpo may have changed in model years ? If the window sticker has it , I would trust it
05-14-2019, 11:13 AM | #10 | |
look for a wire coming out of the bottom of the strut/shock at the lowest point. If there's a wire coming out of it, it's got magnetic struts/shocks. If it doesn't have a wire then it's standard. |
05-14-2019, 11:26 AM | #11 |
I can see the wire coming out of the bottom of the front, but not the rear.
05-14-2019, 11:32 AM | #12 |
camaro only has mag up front it seems. so that's correct.
edit: though it does look like there is a variable dampening shock for the rear ...just not sure if it's magnetic controlled on the mag ride option or variable by mechanical means. The odd part of that one comes out the very top of the rear shock though. Not the bottom. see the bottom images that show what the variable dampening shock looks like https://www.gmpartshouse.com/auto-pa...omponents-scat Might be hard to see without getting under the car. You can also go into the mylink settings and find a suspension setting. Non-MRC cars dont have that screen. Last edited by cellsafemode; 05-14-2019 at 11:43 AM. |
05-14-2019, 01:14 PM | #13 |
I found some numbers on the rear shocks and they are the mag shocks. The parts sources call them variable damping, or variable time damping, etc.
rear left- 84219920 rear right-84219921 I can't find any numbers that look like part numbers on the front struts. But Rock Auto has them with part numbers; Ft. Left - 5801127 (5801114) Ft. Right - 5801128 (5801115) The rears were the only mystery as I couldn't see any wires coming from them. Then I learned the wire comes out the top as Celsafemode suggested. Last edited by overdriv; 05-14-2019 at 02:53 PM. |
05-15-2019, 09:01 AM | #14 |
I still have RPO codes that I can't find;
FJW MF6 NTB WMK Also no code for the transmission unless one of the above codes is the trans?? Any help appreciated. |
