12-25-2018, 08:02 PM | #1 |
Drives: 1LE 2SS Camaro Join Date: Sep 2018
Difference in LT1s?
My curiosity spiked me when reading about the LS1 Vs LT1 Engine discussion. Not just about that but what are the improvements from the late 90s LT1 vs Current LT1? Other than the displacement size & power?
I tried to search it online but I cant seem to string the words correctly to find anything. Not sure how to word it so Google will bring me what I want to see. Thanks in advance! |
12-25-2018, 08:18 PM | #2 |
Drives: 2015 Camaro 2SS 1LE Join Date: Apr 2015
Big difference, here is a good article on it. http://www.superchevy.com/news/ghtp-...1-small-block/
2015 2SS - Base A6 - Sold/Brother/Traded
2016 Camaro 2SS - A8 | MRC | NPP | 725rwhp - RIP 2015 2SS 1LE - RS/Sunroof Mods: Headers, Borla ATAK, intake - Sold 2018 M2 Exec - Current |
12-25-2018, 09:18 PM | #3 | |
So, the bore spacing is probably the only thing that is the same.
12-25-2018, 09:19 PM | #4 | |
12-25-2018, 09:33 PM | #5 |
Drives: 2017 ZL1 Camaro Join Date: May 2018
Nothing is the same to my knowledge. The 90's LT1 was a decent engine but has nowhere near the potential of the LS or modern LT1. There are some significant design hertles that are expensive to overcome in order to make big HP, couple that with the short production run and limited aftermarket support
I still own a 97 Trans Am with a 355ci LT1 with a T-56 and 9 inch rear with 4.30 gears. The heads and intake manifold are stock castings that have been CNC ported. Car makes 438 at the wheels and I still like driving it, its totally different animal than the 6th gen |
12-25-2018, 10:00 PM | #6 |
Drives: 2018 Camaro SS Join Date: Mar 2018
Jeff m
Thank you for sharing this article. Very informative. |
12-26-2018, 07:10 PM | #7 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
There has actually been 3 generations of the LT1 engine.
The 1970 LT-1 5.7/350 CID that was one of the better HP engines for the Camaro for those years. This was back when GM still offered a different corporate engine for each brand. Then the 1992-1996 LT1 5.7/350 CID that was used in the 4th gen F-Body cars. While it was a good upgrade from the L98 TPI engine as it had more power and a better RPM range due to the shorter runner setup, it was a failure because of the optispark system that had engine coolant flowing thru it. Those optispark's died all the time. Then there is the new LT1 we have now, 6.2/376 CID and a clean sheet design. Only 2 parts carried over from the LS series engine into the LT series engine and those 2 parts are nothing major, I think it was a bolt and a bearing for the crank.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
