05-20-2017, 11:42 AM | #1 |
Drives: 2021 Camaro SS Convertible Join Date: Apr 2016
Jet Performance MAF
So, I purchased and installed the Jet Performance MAF a month ago. I usually read a good bit of reviews before I make a purchase and this was no exception. There were a few negatives on this MAF, but most were good. Well a month to the day, the MAF took a crap! It was on my way home from work, in rush hour, on I-95. Those of you on the east coast know how fun 95 is in rush hour! The car started bucking, chugging and eventually, stalling out, a lot! When I got home, I hooked up the SCT that I literally just got the day before, to see if there were any codes. Nothing. so I went in the reverse order of the work I did on the car and the last thing was the Jet MAF. It's funny that in the install instructions from Jet for the MAF, they suggest that you keep your old MAF. Good advice! I kept mine, switched from the Jet to the factory and all is well!
Since then, I've ordered a Granatelli MAF and just installed it, but I haven't had the car on the road to see if there's a difference from stock, I'll follow up later. So, if your're considering a MAF change, I recommend NOT getting a Jet MAF.
2015 SS2/RS, SCT Tune (Dynosteve), Vitesse Throttle Controller, Vararam VR-DRX CAI, Vararam Power Wedge TBS, Granatelli Performance MAF |
05-20-2017, 12:02 PM | #2 |
Drives: cars Join Date: May 2011
They're garbage; they modify OEM electronics to alter the resistance of the sensor to trick your computer. They also have a high failure rate.
05-20-2017, 12:10 PM | #3 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
Might as well just left it in the trash and leave a stock MAF in. They do absolutely nothing for performance.
05-20-2017, 12:15 PM | #4 | |
In theory, they should work. I would imagine it's like any other electronic device in that if you use inferior components, you'll get inferior results. I'm hoping the Granatelli is better. I purchased both through Summit Racing, I'm getting a full refund for the Jet MAF. If the Granatelli fails, I'll do the same and go back to stock. Sent from my iPhone using Tapatalk
05-20-2017, 12:36 PM | #5 | |
05-20-2017, 12:53 PM | #6 | |
05-20-2017, 01:14 PM | #7 |
Rockin' Steady
Drives: 2010 Camaro 2SS Join Date: Apr 2012
He's a 100% right, it's a total waste of money. He's not telling you how to spend your money, he's telling you that your wasting it on something that doesn't work, there's a difference.
Eric Carrier, proud GM Technician for over 10yrs.
2010 Camaro 2SS Black, L99, SLP headers, GMPP axle back, complete JRE tune, 22" Boss 337's, Nitto Invos 5% tint, Eforce Supercharger w. 3" pulley, ADM FPCM, ID850's, JRE fuel rail mod, Eforce CAI, Moroso catch can, spark plug insulators. |
05-20-2017, 01:49 PM | #8 | |
05-20-2017, 01:51 PM | #9 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Snake oil and a waste of money.
05-20-2017, 02:12 PM | #10 |
Drives: 2011 Green SS M6 Join Date: Jun 2015
Like P.T. Barnum said--- There's a sucker born every minute.
05-20-2017, 02:13 PM | #11 |
That escalated quickly
05-20-2017, 02:21 PM | #12 |
Well you're disagreeing with people who are telling you truth. The sensor is there to sense airflow. There is nothing that should be changed on it because it should only be sensing airflow the way GM intended. You're paying extra for an inferior part due to a dishonest 3rd party vendor screwing with a perfectly fine OEM unit, changed the sticker on it, and charging you more. There is no such thing as an improved unit, just someone duped into believing so.
So now you're choosing a different 3rd party vendor who did the same thing. Put your money in a shredder and keep the stock one, your car will be more reliable. |
05-20-2017, 02:22 PM | #13 |
I didn't realize there were so many electrical and mechanical engineers in this forum, that's all.
05-20-2017, 02:37 PM | #14 |
This is shocking news that some people on a car forum may know something about cars. I hate when I inadvertently learning something, really ticks me off.
