Old 09-28-2023, 04:33 PM   #127
SlowLS1
SlowLS1's Avatar
Drives: 2010 Camaro SS , 2011 Colorado LS1
Originally Posted by johnnyb305mia View Post
ZL1 Diff went in the car this past weekend as we wrap up FL2K Prep. Here is a little bit of just the driveshaft difference. Gulf Coast Driveshafts custom shaft to bolt right up to my 1LE Trans and ZL1 Diff. Yoke direct holt in, no adapters or any of that none sense.
Very nice.
What class are you running?
SlowLS1 is offline   Reply With Quote
Old 10-01-2023, 11:17 PM   #128
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
How much was that driveshaft if you don't mind me asking. I would like to fit one to my ZL1 diff...
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 10-02-2023, 06:13 AM   #129
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Interested in your thoughts and experience with the driveshaft. I just installed one on my 1LE recently but the car is down for other services right now and I haven't driven with it yet.
Sent from my Pixel 5 using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
larry_g is offline   Reply With Quote
Old 10-03-2023, 08:16 AM   #130
johnnyb305mia
Drives: 2015 Camaro SS 1LE
Pricing for their products is right on the website. Check out they have options for you. If you need something custom give them a call.
Holley Terminator X Max Single Turbo 6SPD Manual 1LE DSMLIGHTS TUNED
johnnyb305mia is offline   Reply With Quote
Old 10-03-2023, 08:26 AM   #131
johnnyb305mia
As of now I can give initial impressions. We are scrambling to finish everything up not only on this car, but our team has 2 other cars we are in the middle of building/finishing up as well so its hectic right now.
Quality is far superior that what you see from the typical aftermarket options. The customer service has been fantastic! Tight, Perfect Fit upon install. This was all done while car was on jack stands in the garage. Have only backed it out and moved it to allow for one of our other cars to be brought in due to terrible weather over the last 10 days here in SOFLO. Hopefully tonight after a plug wire swap we can test it out. Will certainly follow this up so stay tuned!
Old 04-25-2024, 10:27 AM   #132
johnnyb305mia
Quick Update, Driveshaft 0 issues so far. 4-digit power. Also, we have removed all of the fiberglass wrap and have coated everything. After hitting the rollers last nightie can certainly say the coatings put in work. Engine Bay temps are way down and the best part about it the ability to shorty after touch and work on if need be. I would highly recommend the coatings vs the fiberglass 10/10.
