Old 11-09-2019, 09:03 AM   #1
67 rallysport
67 rallysport's Avatar
Drives: 67 Rally Sport Camaro
Factory ZL1 Rims on a 2017 2SS with MRC - any issues?
Hi all,
I am about to put a set of Factory ZL1 rims on a 2017 SS with Magnetic Ride Control. To the folks who have done this, are there any issues I should look out for?
- Rubbing / Spacing Issues?
- Will the TPMS sensors from the ZL1 wheels work with the SS?
- Will I need to / Is there a way to recalibrate the speedometer?
- something else I haven’t thought of?
Thanks!
67 rallysport is offline   Reply With Quote
Old 11-09-2019, 01:03 PM   #2
L78toLT1
L78toLT1's Avatar
Everything will be fine except the TPMS is not compatible
Baby Blue
Old 11-12-2019, 12:36 AM   #3
Calcanuck
Calcanuck's Avatar
Drives: 2017 Hyper Blue 2SS
Originally Posted by 67 rallysport View Post
Hi all,
Thanks!
Have a set of ZL1 rims on my SS. No issues at all as they are the same spec as SS 1LE. TMPS just needs to be program for your car.
Hyper Blue 2SS, 6MT, NPP, 6 piston Brembo, 1LE suspensions upgrade, ZL1 Seats, Wheels & Tires
Calcanuck is offline   Reply With Quote
Old 11-12-2019, 07:35 PM   #4
67 rallysport
Thanks!
Calcanuck, that is a beautiful car!
After you put on the new wheels, did you do a front end alignment? Any troubles with rubbing or irregular tire wear?
Greg
Old 11-13-2019, 12:10 AM   #5
Calcanuck
Calcanuck's Avatar
Thanks!
Greg
Thanks! No trouble with rubbing. I only got an alignment because I was did a track alignment. Changing to the wider wheels will not pack your alignment. This fitment is designed to fit out cars without modification.
Old 11-13-2019, 04:46 PM   #6
orange blaze
Red Hot SS
orange blaze's Avatar
Drives: 2017 Camaro 2SS
thats a beautiful combo
Do you have a side picture as I would be curious where the front and rear tires sit. Do they poke out past the fender or are they flush.
orange blaze is offline   Reply With Quote
Old 11-13-2019, 04:49 PM   #7
ajp
50th Anniversary Vert
ajp's Avatar
Drives: Camaro 2017 50th Anniversary
Are those 285/30s on the front? I have 275/35, and my wheel gap looks a lot bigger.
ajp is offline   Reply With Quote
Old 03-31-2020, 10:44 AM   #8
JohnC
Drives: Midnight Silverado
Question
Hi all,
Thanks!
Hi Greg!
Any pics of this?
Thank you.
JohnC is offline   Reply With Quote
Old 04-02-2020, 08:34 AM   #9
Yellow Beast
TD
Yellow Beast's Avatar
Drives: 2017 2SS, 2014 Mercedes C300
Did the tire store reprogram the TPMS or did you have to go to the dealer?
Yellow Beast is offline   Reply With Quote
Old 04-02-2020, 09:42 AM   #10
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Both should be able to do it, but if neither of these places do it for free you just need a EL-50448 relearn tool. $10 from multiple places online and useful to have if you're swapping wheels/tires on a semi-regular basis.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
