Vararam
Old 09-16-2019, 11:55 PM   #1
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
Catalytic converter
Does anyone know for sure if a cat from a 2013 camaro ss will fit a 2010. I sold mine and the guy claims they wont fit his car because of the shape of the neck that bolts to the manifold.
StingrayblueSS is offline   Reply With Quote
Old 09-18-2019, 05:03 PM   #2
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
in 2010 and 11 there were no electric power steering units so they had a reservoir and most likely he is talking about that.....
christianchevell is offline   Reply With Quote
Old 09-19-2019, 02:51 AM   #3
StingrayblueSS
I can't see how that would effect the cats. I asked him to test fit them before returning them but he wasn't interested he was just going by pictures on Google. I even sent the part numbers that were stamped on them before I shipped them. I'll post pictures when I get them back.
Old 09-19-2019, 04:48 AM   #4
G8One2
Drives: 2014 Camaro 2SS
Catalysts are no where near any part of the steering system. There are different exhaust for different trim level Camaros, which would have different exhaust configurations.
G8One2 is offline   Reply With Quote
Old 09-19-2019, 07:36 AM   #5
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
Originally Posted by StingrayblueSS View Post
Does anyone know for sure if a cat from a 2013 camaro ss will fit a 2010......
Did you tell him the cats were from a 2013 Camaro?
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
Old 09-19-2019, 09:11 AM   #6
Juiced1
Drives: 2012 2SS CAMARO 45th
The exhaust on these cars changed very little. They should fit fine
Juiced1 is offline   Reply With Quote
Old 09-19-2019, 10:57 AM   #7
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Yea, I don't even think hanger locations changed over the 6 year run. But as for manifolds and the cats? I think it understood that they were interchangeable between all the 5th gen years on LS based cars.
I think the biggest difference was when you go to the convertibles, and that was in tail end of the exhaust.
InFiD3ViL is offline   Reply With Quote
Old 09-19-2019, 11:38 AM   #8
Russell James
Russell James's Avatar
Drives: '15 SS 1LE, '69 Z28 drag car
I looked at the parts catalog for a '13. The left converter part # is for '10-'13. The right (passenger) shows for '11-'13.
So I'd bet your '13 right is not fitting a '10 right.
In the '10 catalog, it shows the right converter as a one year only application for 2010 only.
Russell James is offline   Reply With Quote
Old 09-19-2019, 11:48 AM   #9
StingrayblueSS
I'll post pictures when he returns them. Thanks
Old 09-19-2019, 09:21 PM   #10
StingrayblueSS
I'll post pictures when he returns them. Th5anks
