05-03-2020, 02:56 PM | #1 | |
Drives: 2017 50th Anniversary SS Join Date: May 2018
Bottom back seats can't be put back after taking them out?
At 2:00 this guy said once the bottom back seats are taken out they can't be put back in? I'm not sure if that's the case but I don't want to make any dumb moves just to take out the wire for subs
05-03-2020, 03:07 PM | #2 |
Drives: 2019 Camaro SS M6 Join Date: Jan 2020
That is not true. The bottom isn't bolted at all. It is held in by 2 metal sleeves that clip into the base that the seat sits on. To remove, I used a flat pry bar and slipped under the bolster and pry liberally while lifting with your hand. ( Takes some effort) To reinstall, line up the metal sleeves with the inserts and press down and hear the snap, and it's locked back in place. This is how it was ony 2017 SS. Oh, and if a convertible, the back seat back removal is different. 1st, remove the seat bottom. Then remove the nut from the stud along the bottom of the seat back. Pull up and off, and remove.
Thread Tools | |
