Old 11-26-2018, 10:41 AM   #43
asrautox
Drives: 2017 SS 1LE
Originally Posted by USAFS197 View Post
Have you tracked the car or at least driven it hard since the spring install?
Update: https://youtu.be/Qx_v3Gx4nZo
Ran the car at Cal Club this weekend. Was the 2nd fastest rwd v8 car there. The fastest was a Shelby GT350 CAM car that was trailered in. He ran a 30.9 to my 31.3. I’d say the springs work just fine on this car
Sent from my iPad using Tapatalk
2017 1SS 1LE - Eibach Springs | Pray IM | Katech TB | Borla 60606 | Corsa Extreme | E85 Flex Tune
asrautox is offline   Reply With Quote
Old 11-26-2018, 03:07 PM   #44
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
Tracks are really not a good place to test lower springs. most tracks are prepared surfaces not subject to the general population.
Tracks almost always benefit from lower and stiffer as they are mostly a lot smoother without the uneven pavement, expansion joints, etc. that roads have to deal with
Unless you are at The Ring, most tracks can hide most bad behavior that springs have because they are too smooth to really test them.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 11-26-2018, 03:24 PM   #45
asrautox
Drives: 2017 SS 1LE
I’m not sure I understand your logic. So other than Nurburgring, where else can we properly evaluate the effectiveness of a particular spring? Certainly not on the street.. Either way, this was an Autocross in a parking lot with tons of ruts and surface defects, not a prepared track.
Old 11-26-2018, 04:35 PM   #46
wrankin
Camaros Of Northwest Ohio
Drives: 2016 Black 2SS
Is a stock 1LE the same ride height as stock SS, or is a 1LE lower?
Bill
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold)
2023 GMC Canyon Denali
2013 2SS / RS - AGM / Jet Black (sold)
1970 1/2 Z/28 Classic Copper / Tan (sold many years ago)
wrankin is offline   Reply With Quote
Old 11-26-2018, 07:11 PM   #47
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Bill
Here's my calculations comparing the base SS, SS 1LE, and base SS with GM lowering kit. Note the spring and tire height differences.
Based on my calculations, the SS 1LE springs alone are lower than the base SS springs by the following:
Front: 0.336" lower
Rear: 0.579" lower
Overall ride height on SS 1LE (considering both wheel/tire combo and springs) is lower than base SS by the following:
Front: 0.828" lower
Rear: 0.766" lower
Therefor on base SS, the GM lowering kit combined with SS 1LE wheel tire package would sit:
Front: 0.44" lower than SS 1LE
Front: 1.27" lower than base SS
Rear: 0.20" lower than SS 1LE
Rear: 0.96" lower than base SS
Numbers that went into calcs above:
SS 1LE:
Front wheel diameter: 26.73"
Front ground to top of arch: 27.875"
Rear wheel diameter: 27.20
Rear ground to top of arch: 28.0625"
Base SS:
Front wheel diameter: 27.72"
Front ground to top of arch: 28.70"
Rear wheel diameter: 27.58
Rear ground to top of arch: 28.83"
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 11-26-2018, 07:27 PM   #48
wrankin
Front: 0.336" lower
Rear: 0.579" lower
Front: 0.828" lower
Rear: 0.766" lower
SS 1LE:
Base SS:
Wow, that's an extremely detailed answer. Thanks for all of the info.
The reason for my question is I just purchased some 1LE replica wheels and I plan on getting the 1LE tire fitment and wondered if that wheel and tire combination is going to fill the wheel wells OK.
Thanks again,
Bill
Old 09-14-2019, 07:41 AM   #49
Johnkout1
Johnkout1's Avatar
Drives: 2019 ZL1 1 LE
There’s some pictures of lowered 1LE’s in the specific 1LE sub forum. However, there’s a lot of hate surrounding that so, be forewarned.
I noticed that and its unfortunate people are that way. I wish the moderator would block them. We dont need that negative talk.
Johnkout1 is offline   Reply With Quote
Old 09-16-2019, 07:16 AM   #50
Soleil
Soleil's Avatar
How do I get the 1LE suspension mapping on a normal SS with lowering springs with MRC?
Soleil
Old 05-27-2020, 10:30 PM   #51
Trochoidal
Drives: 2017 Camaro 2SS A8
Hey Soleil did you gain the knowledge/information to this question?
