02-14-2011, 01:23 PM | #1 |
Senior Camaro Fanatic
Drives: 2011 SS/RS manual - White Join Date: Aug 2010
Tune, gears, warrantee, all that stuff again...but
Let's not rehash all the warrantee stuff, but I thought I might approach this from a different angle So Ted...help me here
My main subject is gears. And I would be the guy wanting to protect my warrantee as much as possible. It seems to me gears and a CAI may be the best way to go for us on the fence and not wanting to tune an otherwise stock Camaro to get that extra 15hp and some more fun in the drivability...So....4:10's in a SS M6 and add a CAI My questions are: What happens with the factory torque management settings when you install new gears...do they continue to defeat you? Or do you get multiplied torque...how does this interact with the new gears Do you have to flash the ECU to fix the speedometer? It seems like I could simply tell the dealer what I've done and lose only the warrantee on the rear end. And if there is tweeking to be done for the speedometer, let them do it |
02-14-2011, 01:48 PM | #2 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2010
I believe the dealer can do it with the MDi. Best to talk to them and see. Otherwise yes, you'd have to program the PCM and the TCM if an auto
02-24-2011, 12:24 PM | #3 |
Bump...I still have not got an answer. Hep me pls
Manual transmission What happens with the factory torque management settings when you install new gears...do they continue to defeat you? Or do you get multiplied torque...how does this interact with the new gears |
02-24-2011, 09:21 PM | #4 |
Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
dealer can not do any programming or adjusting other than the latest factory file
415ci stroker, TVS 2300 Magnacharger, cnc heads, cam, yank ss3200 converter, Kooks long tubes, Bwoody true cold air kit, ZL1 Pump, magnaflow 3" cat-back, lowering springs,BMR control arms and tie rod bars, 3.73 gears, diff mounts, RX can, ADM fuel controller
02-24-2011, 09:34 PM | #5 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
if you dont reduce torque management with a computer program, it will stay attached and remain active. Although you may defeat your CAGs with high enough gears and wouldnt have to tune them out.
you can install a procharger, bolts ons, heads and cam, but you'll still have TQMT unless you remap your system |
02-25-2011, 09:59 AM | #6 | |
2) Yes,Change the Gears you have to tune to correct the speedo and for the 4 wheel ABS to work right. 3) I don't think the Dealer can change the speedo cal. Ted.
www.jannettyracing.com
02-25-2011, 10:13 AM | #7 |
Thanks Ted..I get it. So in short, gears are not a solution to "get around tuning your car"
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Official 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 3652 | 08-17-2023 02:50 PM |
MarylandSpeed DYNO TESTED: Diablosport Predator Canned Tune on 2010 SS A6 | MarylandSpeed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 27 | 05-18-2013 10:01 PM |
Standard vs Automatic Racing | HarrisraTx | Dragstrip and Launch Techniques Discussion | 74 | 10-29-2010 09:26 PM |
Undetectable Tunes - What You Should Know | kelley@vectormotorsports | V8 Bolt-Ons & Tunes | 159 | 09-18-2009 02:18 PM |
LS3 goes 11`s Bonestock! | GMRULZ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 12-08-2008 09:10 PM |
