Old 07-13-2018, 08:01 AM   #1
parkersextonn
parkersextonn's Avatar
Drives: 2018 Camaro 2SS 1LE
1LE - Hard Water Spots On The Hood
I'm sure i'm not the only one to experience this. I have looked around on here already, but I have seen so many different opinions & answers that I am not quite sure which one to go with. When it comes to removing hard water spots on your hood, what is the best product & easiest way to do so? I had my car for not even a day & already had water spots on the hood & I have been searching for a way to remove them ever since.
parkersextonn is offline   Reply With Quote
Old 07-13-2018, 09:00 AM   #2
bullet3z
Drives: 2018 1SS 1LE
Multiple options on how to clean.
https://www.camaro6.com/forums/showthread.php?t=527988
bullet3z is offline   Reply With Quote
Old 07-13-2018, 09:03 AM   #3
ToeKnee Sea
Drives: 2018 Camaro SS 1LE
Chemical Guys makes a Satin cleaner/protectant that I've been using and it works great
ToeKnee Sea is offline   Reply With Quote
Old 07-13-2018, 09:41 AM   #4
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2017 ILE SS
White vinegar should remove calcium deposits.
Bad Anvil Garage is offline   Reply With Quote
Old 07-13-2018, 01:11 PM   #5
MJP
MJP's Avatar
Drives: 2018 Camaro 1LE Summit White
Yes!
Short story,
I purchased a new Indian Motorcycle back when they first came out in 14.
It was in the middle of winter. I trucked her home and put her in my basement.
I have double wide 6' doors leading to the basement.
She was parked and sat until spring.
April arrived. I went to the basement to roll her out.
I have very hard Water from an Artesian Well. The shit is like Acid.
My front fender was all covered with water spots, cancer.
It felt like someone had poured hot honey on a countertop and let it set up for weeks.
WTF, where did this come from?
I looked above. There was a copper cold water pipe running right above the fender.
The Pipe didn't even look bronze copper. It was totally green\blue colored. The SOB had fur growing on it.
Moisture and Condensation sweating. Living in a nest and dripping.
Dripping on the fender.
""White Vinegar"".
I poured some in a bowl and brushed it on with a brush. I let it sit for about five minutes.
All the Cancer wiped right off with zero effort. The paint was as good as new.
MJP is offline   Reply With Quote
Old 07-13-2018, 01:34 PM   #6
satanschariot666
Drives: camaro
how old are teh water spots?
i put some on my car just by getting sidetracked and cleaning the wheels before drying off the body.
its frikken insane how fast those basterds form.
i ended up flipping out the rest of the night, could not get them off.
the next day i got mcguires detail box, claybar and spray and cloth.
first time using clay and its amazing few rubs and water stains were gone.
even removed the spots and scratch that came from the dealer.
however! later that day i went to the beach.
looked at the spots again and they are back.
i pretty much got depressed at that point since that would call for buffing.
but! after leaving the car in the sun and heat for a few days the spots have disappeared completely now.
hope that helps.
satanschariot666 is offline   Reply With Quote
Old 07-13-2018, 02:21 PM   #7
Kise
Kise's Avatar
Drives: 16' 2SS, 06' Silverado SS
weird. on my Satin matte I just use a normal auto soap on the whole car.
none of these goofy products for the inside and out and I used to show room detail when I was younger.
it seems like the water from my hose and auto soap (which contains like a wax type seal for the time being, they say not to use it.) works just fine and leaves it spotless. you must have really hard water in your area or maybe you should treat your wrap.
I have 3m 1080
Kise is offline   Reply With Quote
Old 07-13-2018, 05:58 PM   #8
50MileSmile
50MileSmile's Avatar
Drives: 2023 2SS, 2018 1SS 1LE, 1993 Z/28
Once you get the water spots removed, use Adams Matte Detailer to protect the black vinyl on the hood. Adams even uses the 1LE as its example of where to use the product.
I had the entire hood covered with Xpel, along with with the rest of the front of the car and the rocker panels to avoid the water-spotting problem and rock chips. The OEM black vinyl does not prevent rock chips.
50MileSmile is offline   Reply With Quote
Old 07-13-2018, 06:52 PM   #9
satanschariot666
Drives: camaro
**** i just went and looked for teh spots again trying to angle the sun and i see teh ring still
Old 07-15-2018, 04:24 PM   #10
Camarentino
Camarentino's Avatar
Drives: 2018 Camaro 1SS 1LE
I used a vinyl cleaner but now my hood is satin looking not matte. I actually like it better tho. Not sure if you can tell
2018 Camaro 1SS 1LE w/PDR Summit White
KN intake-MBRP cb- 2nd cat deletes- ACS sides- iroc Z spoiler- Eibach Pro- Katech 95TB- MSD Manifold-GM strut bar- Custom tune by Arun Ahuja @ CCPERF.ca
Camarentino is offline   Reply With Quote
Old 07-15-2018, 06:09 PM   #11
zr1chris
zr1chris's Avatar
Drives: 2018 Camaro 1SS/1LE
Did you have it re-wrapped or is it from using the cleaner? If it's the cleaner which one so I can get some?
zr1chris is offline   Reply With Quote
Old 07-15-2018, 06:35 PM   #12
Camarentino
No re wrap just the cleaner. It's called Autoglym. I think it's a British company. I got it locally
Old 07-15-2018, 06:56 PM   #13
zr1chris
zr1chris's Avatar
This?
http://www.tcpglobal.com/AUT-06500.h...E#.W0vfFCMpA0M
Old 07-15-2018, 06:59 PM   #14
Camarentino
That's the stuff. I use quite a lot of their line up
1le, 1le camaro
