Old 06-19-2017, 10:29 PM   #1
gus0671
Drives: 2010 Camaro RS
2010 V6 manual transmission shifting issue
Hey guys, I have a 2010 3.6L Camaro RS 6Speed manual. I've had the car for 4 years now and I've never had an issues with it, up until now. the car has about 83k miles and lately I've been having a shifting issue, the clutch isn't sticking, slipping, or grinding the gears, Its hard to shift into gear. I struggle the must to get it into reverse and first gear. If anyone has any ideas or any suggestions that might help. It would be greatly appreciated, please and thank you !
gus0671 is offline   Reply With Quote
Old 06-19-2017, 11:55 PM   #2
riozlander
that guy <--------
riozlander's Avatar
Drives: 2012 camaro V6 LS M6
synchronizers might be worn out in the trans best guess i got
riozlander is offline   Reply With Quote
Old 06-20-2017, 12:06 AM   #3
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
Has tranny fluid ever been changed?
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 06-20-2017, 09:10 AM   #4
Dusman23
Dusman23's Avatar
Drives: 2010 Black Camaro RS Package
Its the clutch. I had the same exact problem with mine. Mine has 85k miles on it. Just got the car back yesterday after a new clutch and flywheel and it works perfectly now.
Dusman23 is offline   Reply With Quote
Old 06-20-2017, 09:48 AM   #5
Jazzzed
Jazzzed's Avatar
Drives: 2015 Camaro LT
The clutch isn't releasing fully. Therefore it keeps spinning the input shaft to the transmission. The trans won't allow shifting into other gears when the input shaft is spinning. It will either be a slave cylinder, or something binding on the clutch itself. Could be the master cylinder too, or even air in the lines.
Jazzzed is offline   Reply With Quote
Old 06-20-2017, 08:45 PM   #6
gus0671
thanks guys, and I've yet to change any fluids since I've got it, other than oil changes. The dealership said they did a complete fluid flush when the car came in. Im coming to the conclusion i will have to change out the clutch
Old 06-21-2017, 07:31 AM   #7
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Can you put in to 1st and reverse when the car is off? If so that points more to a worn clutch, or like Jazzzed described.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
Old 06-21-2017, 08:20 AM   #8
Avenging Orange
I'do a tranny fluid change for piece of mind. Maybe check and refresh the brake/clutch reservoir.
Not too many dealerships perform such duties like they did back in the day....when the costomer was king.
Old 06-21-2017, 09:42 AM   #9
WoodBoss
"Old School"
Drives: 2010 2SS L99
Sounds like your clutch may be not fully disengaging. When you are moving does it shift easier?
WoodBoss is offline   Reply With Quote
Old 06-21-2017, 10:40 AM   #10
Foxfire15
Drives: 2015 2LT/RS BVM
Sounds like a clutch / clutch plate to me. Had a plate fail with similar symptoms on my first car and it left me stranded in a little podunk town. Dad ended up power shifting the SoB home. I'd get it into the shop sooner rather than later.
Foxfire15 is offline   Reply With Quote
Old 06-21-2017, 10:41 AM   #11
RubberChicken
RubberChicken's Avatar
Drives: 2011 IBM 1LT w white Rally Stripes
Clutch. I had a similar problem with the very first car I owned. The clutch was going out and had to be replaced.
RubberChicken is offline   Reply With Quote
Old 06-21-2017, 02:23 PM   #12
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Yes it's the clutch not disengaging. Fix it soon before you damage the gears.
You can go ahead and change the transmission fluid, but that's not gonna fix anything. In manual transmissions, the fluid gets very little stress or contamination.
Old 06-21-2017, 03:39 PM   #13
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
The pressure plate fails. with enough use the springs loose their spring.
But no sense to replace only the pressure plate as the rest of the parts aren't far behind.
Be sure the estimate includes the throw out bearing and fork. May as well get all the bits for the labor cost.
You don't have to actually power shift, rev-matching works. Probably what your dad really did.
when you need to stop slip it into neutral. turn the key off after stopping (so you have brakes and steering until you stop). When it's time to go, have it in 2nd and hit the starter. And away you go. A bit of careful upshifting without a clutch can get you up to highway speeds.
Anyway, sometimes those small towns can fix it quick enough and get you on the way for a lower cost than bringing it home. And they have the best breakfasts!
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 06-21-2017, 03:43 PM   #14
Jazzzed
Jazzzed's Avatar
Yeah, if you're going to drop the trans, then get it all done. Clutch, slave. I'd even consider a new rear main seal. The car is 7 years old.
clutch, issue, manual, shifting, transmission
