03-04-2016, 05:38 PM | #1 |
Owning SSes for 50 Years
8A - Are Drag Radials Really Neccessary
I read every thread relating to drag racing the 8A 2016 SS Camaro and I am of the opinion that drag radials might help to some degree, but aren't necessary for great ETs.
The reason I post and ask this question is: I have a set of 17" drag radials 315 35 17s, mounted on 2002 Corvette Z06 front wheels. I think they're 10.5 inches wide and they were the same height of the 20" wheel/tire on my Grand Sport. They fit perfectly on my 2010 C6 6M Grand Sport and hooked decently. I haven't tried them on the new car yet, it's only a week old and has only 600 miles on it, so it's not broken in. With all of the 1.8 60 foot times posted on these threads, I'm not sure it would be worth the effort to put them on. When the weather warms somewhat, I will test fit them. Usually the problem with fitment is the brake caliper width and the Grand Sport was much bigger than the Gen6. Any thoughts?
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars: 1966 Chevelle SS 4M, 2010 Corvette 6M 1968 Dodge Charger R/T Auto 2012 1SS 6M 1982 Corvette Auto 2010 1SS 6A 1984 Corvette Auto 2016 2SS 8A 1999 Camaro Auto 2017 HBM 1SS 1le 2002 C5 Corvette 6M 2018 2SS 2006 Corvette Auto 2023 Camaro LT1 |
03-04-2016, 05:40 PM | #2 |
Drives: SS 6 speed of course Join Date: Jan 2016
depends on the track, Houston, and SA have great tracks and prep. Central Texas has really poor track and prep, so 2.1 is more the norm. I bracket race and you really want the consistency of the DR.
03-04-2016, 05:51 PM | #3 | |
From one old man to another...thanks. I intend to take the car to the track (125 miles away in Memphis) bone stock and run it that way. If my wheels and tires fit with no trouble, I may try them, but I hate to drive it that far on drag radials especially with no TPMS in the drag radials. The wheels won't fit in the new Camaro trunk, but would in the GS. My Grand Sport would not run over 4,000 rpm when the tires registered no air???. I had to take out the traction control relay to run at the Holley LS Fest last year...unsuccessfully, by the way...lol. I won runner up in bracket class the first LS Fest year with my 2010 L99 Camaro. After that first year, they moved to index which I hate.
03-04-2016, 08:54 PM | #4 |
Drives: Camaro 2SS A8 NPP Join Date: May 2015
Yes, you will need drag radials
Mosaic Black 2SS A8 NPP
12.08@115 MPH |
03-04-2016, 09:03 PM | #5 |
Drives: 2016 Camaro 1SS A8 Join Date: Jan 2016
Drag radials helped with consistency, and after the stall we swapped to a full Hoosier slick.
We are running OEM Front C5Z06 wheels on ours, we had to grind the calipers around the tips and alittle in center, overall not bad.
2016 1SS A8
7.9 @ 90.79 Stock with a tire 7.20 @ 94.71 LBO getting kicked out Now tuned on E85, CA Performance Test pipes & Circle 4C 3800 stall shooting for low 7's next time out. |
03-04-2016, 09:07 PM | #6 |
So, you encountered some interference with the calipers? You wouldn't have a pic of the grinding you had to do, do you? That sounds promising. What size tires did you use on the drag radials. Thanks.
03-05-2016, 05:51 PM | #7 |
I've included what pics I have. These are Hoosier 28/10.5/17 Slicks. I've cut a best of a 1.52 60" foot with them.
2016 1SS A8
03-05-2016, 11:42 PM | #8 |
haha nothing will stop a man on a mission that is awesome! I love the progression in your signature. I know the A8 is better, I'm green jelly!
03-06-2016, 12:03 AM | #9 |
please give us a review of the CA test pipe, really high quality piece. Did you move the rear 02 behind the unmanaged cat or just program them off?
03-06-2016, 12:55 AM | #10 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Stock car, well prepped strip...no drag radials needed.
03-06-2016, 05:32 AM | #11 |
You should see a couple tenths pick up with DR's
03-06-2016, 05:34 AM | #12 |
CA, are those 17x8 or 9's or 10's?
03-06-2016, 08:19 AM | #13 |
From the Vette site they are 9.5s
Stock Z06 Wheel/tire sizes 2001-2004 Z06 Front: Wheel size: 17 x 9.5 Offset: +54mm Tire Size: 265/40/17 Back Spacing: 7.38” (187.35mm) Rear: Wheel size: 18 x 10.5 Offset: +58mm Tire Size: 295/35/18 Back Spacing: 8.03” (204.05mm
03-06-2016, 08:29 AM | #14 |
I ran the corvette wheels on my supercharged g8gt for my drag radials.. I just wanted to see what he was running on his hoosiers. I'm probably just go ahead and run a 20" drag radial after I get my new wheels for the car and use my 5 spoke 20x9.5's for my Dr's or go back to an 18 on the rear. A few more options in the 18's then the 20's. I'd like to have a little more side wall also. I think it will launch better as it did on my g8.
