dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 03-17-2015, 09:05 PM   #1
mnvaughn
mnvaughn's Avatar
Drives: Camaro
Crank Pulley Install Tools
In November I had an ATI lower pulley installed on my car and I had to take it off due to the supercharger recall. Install and removal cost 700 dollars each by my tuner. I now plan to reinstall my larger lower pulley again but I want to avoid having to go through a tuner again (only for the tune). What are the necessary tools that I'll need to pull off the stock pulley and place the new pulley? So far I have found these as the necessary tools:
1. http://www.autozone.com/loan-a-tools...er/391370_0_0/
2. https://sdparts.com/details/scoggin-...-center/sd6628
Are there any other tools that I'll need? I know there is a tool to help walk on the AC belt, but I know it can be done without it because I actually helped my mechanic walk it on without it.
mnvaughn is offline   Reply With Quote
Old 03-17-2015, 09:10 PM   #2
Blueclyde
Drives: 2023 ZLE
Those are the only special tools that you will need.
Blueclyde is offline   Reply With Quote
Old 03-17-2015, 09:13 PM   #3
mnvaughn
mnvaughn's Avatar
Drives: Camaro
Perfect! Thanks for the quick response!
Old 03-18-2015, 06:47 AM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
yes...those are the two "right" tools to make it an easy task. Walking the A/C belt on with your fingers or a socket extension to help tension the belt is the only thing I have ever used. The special tool wouldn't fit when I tried to use it because of the A/C compressor clutch.
Old 03-21-2015, 07:44 PM   #5
billjw
Drives: 2013 ZL1 Black
you do know ATI has a install/removal kit right?
billjw is offline   Reply With Quote
Old 03-21-2015, 07:45 PM   #6
billjw
http://www.atiracing.com/products/dampers/damperparts/
Old 03-22-2015, 08:37 AM   #7
Stephen12ZL1
Drives: '21 ZLE A10
yep...make sure you get the special LSx stud with the ATI kit. The ATI kit doesn't work well for removal of the stock LSA pulley in my opinion. It removes an ATI pulley perfectly. Get the Chrysler 3.5L pulley tool with push rods for the easiest stock LSA pulley removal tool.
Old 03-23-2015, 11:51 AM   #8
96ss1664
96ss1664's Avatar
Drives: 1996 Z28/SS, 2013 ZL1
Couldn't you make a install tool pretty easy?
13 Camaro ZL1 IOM #3976
96 SS Camaro #1664, 04 2500 Dirtymax
ZL1 Current Mods: KOOKS 2" w/orp, BTR Stage 3 Cam, LPE 2.55, LPE 9.1, ATI Damper, LPE Isolator Coupling, LPE CAI, Ported TB/Snout/Blower, JMS BAP, ID-850, 160 T, Ron Davis HX, D3 Reservoir, Elite Eng CC Gen2...
96ss1664 is offline   Reply With Quote
Old 03-23-2015, 02:51 PM   #9
Stephen12ZL1
Drives: '21 ZLE A10
Yes...threaded rod M16 x 2.0 and 2 large washers + nut would also suffice. The Scoggin Dickey tool listed above is far superior and very easy to use. I installed the pulley so easily that it was ridiculous.
Old 03-23-2015, 05:55 PM   #10
96ss1664
96ss1664's Avatar
ati, install, lingenfelter, pulley, tools
