05-05-2020, 09:20 PM | #1 |
Drives: 2018 Camaro 2SS A8 Join Date: Dec 2019
305/45/17 ET Street R Tire Pressure?
Just picked up my RaceStars & 305/45/17 ET Street R's today
Was curious what kind of air pressure everyone is finding works best. Seems like a lot of people I talked to are running in the 18-21psi range. Unfortunately the tracks are not open here yet, so street tuning and Dragy #'s is the best I have to work with for now.
2018 Camaro 2SS A8 Redline Edition
05-06-2020, 05:22 PM | #2 |
Yea... all closed down here as well! You want to run as much air as you c an in them... My power level I run 18Lbs with a 1.42 60Ft. Same exact tire I run!
2018 ZL1-NFG-A10
New Iron L8T 9.37 148MPH |
05-07-2020, 03:53 PM | #3 | |
Yeah that's the plan, probably start around 18 and work my way up until i start to see the 60's drop. Was just curious what everyone else was running on these cars. Hopefully the tracks open soon!
05-07-2020, 04:43 PM | #4 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
I'm running Hoosier, but they could be relative. Last time I ran, I was dead hooking with 24. I've mostly ran 18 to 20. All depends on the track prep and conditions.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
05-08-2020, 09:43 AM | #5 |
Drives: 2016 Camaro SS Join Date: Sep 2018
Around 20 was what I found to hook the best at the track, I run them at 25 on the street.
05-08-2020, 01:42 PM | #6 |
My best 60 ft is 1.35 with the same tire on 19 psi.
05-08-2020, 07:56 PM | #7 |
Thanks gents,
The temps dropped here the past day or so out of the blue, we actually got some flurries this morning. So will have to give it a few days to warm back up again so I can make a run to Mexico and give these a try...
05-08-2020, 10:26 PM | #8 |
Is anyone changing the tire size scaling in HPTuners to keep all the mph/etc in proper calibration when running the DR's vs Street tires?
I haven't physically measure the height difference between the stock wheels, although I'm sure it close.
05-09-2020, 12:02 PM | #9 | |
Sent from my SM-G955U using Tapatalk |
05-09-2020, 12:46 PM | #10 |
I had that same tire before and there is no question that it's taller than the stock SS tire. Made the unadjusted speedometer read lower.
05-09-2020, 03:25 PM | #11 | |
I am not too worried about the speedo being off, but alot of the trans related stuff like shift points are based off mph I believe so I would like to keep it consistent.
05-09-2020, 03:43 PM | #12 |
I'm not sure what you guys are talking about but a 305/45/17 is a 28 inch tire just like the stock 20s. If it is different it is by a very small percentage like .20 or something and won't affect the speedo enough to even worry about.
05-09-2020, 03:47 PM | #13 |
I just looked it up and the stock tire is 27.58 and the 305/45/17 is 27.8 which is not enough difference to even notice.
05-10-2020, 01:16 AM | #14 | |
I appreciate the info!
Thread Tools | |
