05-31-2020, 07:45 AM | #57 | |
Drives: Mustang Join Date: Dec 2015
Good to know, sounds like I'm a green light to throw one on and enjoy some additional blower noise. |
11-17-2021, 01:49 AM | #58 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Having read several threads in these forums and considering that I am not planning to tune the car, I will add the drop-in K&N filter (# 33-5047).
Mosaic black 2018 Camaro 2SS A8 (sold) Last edited by MakCamaro; 11-17-2021 at 06:36 AM. |
11-17-2021, 06:29 AM | #59 |
To save some money on the panel filter, Summit Racing has their house brand filter that is cheaper than the K&N. Same look and cleans like the K&N too.
11-17-2021, 06:36 AM | #60 |
Makis
Thanks for the info Greg. Is that the one for the ZL1?
https://www.summitracing.com/parts/SUM-239621 EDIT: Actually the Summit Racing filter panel is more expensive than the K&N one because of shipping and import taxes. I can find the K&N locally. Thanks anyway mate.
Mosaic black 2018 Camaro 2SS A8 (sold) Last edited by MakCamaro; 11-17-2021 at 06:54 AM. |
11-17-2021, 01:27 PM | #61 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Isn't the green filter supposed to offer better performance than a K&N?
11-17-2021, 01:58 PM | #62 |
this is the same one i have on my car but the zl1 version its pretty damn nice...
https://afepower.com/afe-power-57-10...-pro-5r-filter
11-17-2021, 05:44 PM | #63 |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
I just watched two separate dyno tests of a K&N drop in panel filter for a Camaro SS - the first one gained 5 peak rwhp, and the 2nd gained 9 peak rwhp. These were back to back runs on the same car, like minutes later.
As I said earlier, I'm willing to bet some of the gains over this that a CAI shows on a dyno is due to the hood being opened. ~5 rwhp for $70 is a pretty decent bang for the buck, and it has no effect on warranty. I think a ZL1 would see even more of an increase due to a lot more airflow than an SS, but I couldn't find a dyno test to prove it.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
11-17-2021, 07:26 PM | #64 | |
11-19-2021, 11:10 AM | #65 | |
Drives: 2018 ZL-1 Join Date: Jan 2018
Here is a link to a scientific ISO 5011 air filter test, wherein they tested 9 filters, from paper filters to K&N, to UNI, which I think is a foam filter. These tests were performed on an expensive test unit that had standardized dust grains, with standard fixtures for holding the filters, and accurate measurement gauges. The K&N not only passed the most dust, but it clogged earlier than all the others. I used to drink the K&N Koolade, but not any more. Actual air filtration is what's important to me, and a little more blower whine is not worth massive dust ingestion into my engine. Stock filters are best - for filtration. http://www.billswebspace.com/AirFilterTest.htm |
11-20-2021, 06:07 AM | #66 | |
Again, I am talking about my SS not gaining any performance, have not tried it with a ZL1. |
11-25-2021, 12:19 PM | #67 |
Drives: 2018 ZL1 Join Date: Dec 2020
Anybody have a PN for the pre-filter if they run one on a Roto-Fab Big Gulp?
11-26-2021, 08:41 AM | #68 |
I agree. I was in a muffler shop over 25 years ago and they had a K&N display where there was air blowing through a paper filter similar to a factory filter and through a K&N filter. The air was sending ping pong balls up clear tubes. The K&N filter was obviously lifting the ball quite a bit higher than the OEM type filter. I removed the K&N filter from the display and held it up to the light. You could easily see light coming through holes in the gauze even with the oiled media. It's obvious they can't filter like a paper filter, so silica would get into your engine & oil accelerating wear.
11-27-2021, 05:16 PM | #69 |
Drives: Chevrolet Camaro ZL1 Join Date: Jan 2020
Have one for sale
Its about 5 months old. Dry filter. I had a e60 tune and went with the Big Gulp. P/N 10161057. $375 plus shipping. Like new.
11-28-2021, 12:33 AM | #70 | |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
I've heard people claim actual sand gets through the filter - ok, maybe if you drive in a desert and/or live/drive in a very dusty area. I've removed my filter multiple time to inspect and the intake is spotlessly clean. There is hype on both sides of this debate. Three sides to every story. I believe most of the power gains (call it 3-5 hp depending on conditions) is largely in the element itself. The restriction is not in housing unless you're pushing ~700+ rwhp |
