Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 09-24-2012, 03:51 PM   #1
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
roto-fab check engine light.
Just installed a roto-fab cai on a 2010. Check engine light is on. I followed all the instructions so I'm not sure what it could be. Any ideas of what could be causing this? Also, the rubber seal on the top causes the hood to be off level. Any suggestions welcome.
Old 09-24-2012, 04:54 PM   #2
2010camarolt
2010camarolt's Avatar
Drives: Victory Red 1LT
the box is not set in all the way. take the tube off and there a little stud at the bottom of the box. it lines up with a hole. i had to use a pretty good amount of force to get it in. i had the same problem (with the box) and it was an easy fix
i attached a picture. This is NOT the right way to have it installed. The box is sitting to high. The black seal of the box should be inline with the black seal that seals the hood
Edit i just noticed you have an SS you might want to check with v8 group about the cel
2010camarolt is offline   Reply With Quote
Old 09-24-2012, 05:00 PM   #3
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
It is set in right. The rubber seal is even with the front weather strip. This is a mpd1 hood.
Old 09-24-2012, 05:01 PM   #4
2010camarolt
sorry i cant help then
Old 09-24-2012, 05:04 PM   #5
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
No problem I'll give it another try to see if it will set lower
Old 09-24-2012, 05:49 PM   #6
usafboy
usafboy's Avatar
Drives: 2010 Silver SS/RS LS3
move to the V8 thread or search for rotofab in the v8 section, i'm sure someone will help you out, not much us v6'ers can do for you
2010 Silver Ice Metallic Camaro SS/RS LS3
Mods...so far: resonator/muffler delete, tinted everything, '13 shift knob/boot, bowtie delete, PFADT sway bars, CAI intake, Hurst short shifter, JBA cat deletes, BMR trailing arms/outer bushings/steering rack bushing, Bo White ported TB.
Rhino79 Dyno tuned...405 HP/399 TQ
usafboy is offline   Reply With Quote
Old 09-24-2012, 07:56 PM   #7
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
This is a v6 I'm talking about. Fuse pull fixed the cel. But the hood is still of. I think the rubber strip provided is too thick.
