Old 05-19-2018, 12:56 PM   #1
Bucks SS
Drives: 2016 2SS
exhaust sound change
I have 2SS with A8,NPP and love to drive using paddles for shifting. I also run exhaust in track mode so you get that throaty sound when shifting and running with revs up a bit. Today I was driving in 3rd gear and lost that nice exhaust sound almost like I had switched to stealth mode, I checked flappers in exhaust and they were wide open but now I don't have any sound coming from car. Anybody have any ideas what the problem could be?
Bucks SS is offline   Reply With Quote
Old 05-19-2018, 01:39 PM   #2
Gen6_1Le
Gen6_1Le's Avatar
Drives: 2018 Camaro 1Le
May have something to do with the AFM valves kicking in .
Gen6_1Le is offline   Reply With Quote
Old 05-19-2018, 06:49 PM   #3
Drags1998
Drives: 15 SilveradoLTZ,162SSVert BlazerRS
Its NOT a problem, That's the way it works. Next time it gets Quiet, Step on it, It WILL get LOUD again!!!!
Drags1998 is offline   Reply With Quote
Old 05-20-2018, 02:17 AM   #4
misterjaayy
Drives: 2019 CTS-V
The valves automatically close at cruising speeds to prevent drone. Some people pull the fuse for the NPP valves so they stay open all the time. Can’t remember which fuse it is but you can search and find out.
misterjaayy is offline   Reply With Quote
Old 05-20-2018, 06:32 AM   #5
mdhopt36
Drives: '17- 1ag37 V6 traded, for 1SS 2018!
I pulled what I thought was the fuse, and no difference. The diagram on the fuse cover was -NOT- consistent with the actual arrangement of the fuses either.
I guessed where the fuse was by what was ajacent preceding the actual amp fuse- 3-10 amp, 1-15 amp, followed by another 10 amp just before the 15 amp one you're supposed to pull.
I just shoved it back in- far as I know, nothing was deactivated.
I leave it in track mode right now.
What's wrong with drone?
mdhopt36 is offline   Reply With Quote
Old 05-20-2018, 10:01 AM   #6
Gen6_1Le
Gen6_1Le's Avatar
I believe the AFM has another set of valves that is not effected buy the fuse pull , has to do with the need for back pressure .
Old 05-20-2018, 10:05 AM   #7
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
It gives you a headache after a few minutes.
craigss50 is offline   Reply With Quote
Old 05-20-2018, 03:04 PM   #8
Sev
Sev's Avatar
Drives: 2016 2SS / 2004 Tacoma
Fuse 51
2SS, Manual, Blue Velvet Metallic, Medium Ash Grey, Black Wheels, MRC, NPP, Black Bowties, Black GM Tail Lights, Oracle LED side markers.
"I'm going to drink you pretty, beautiful toad"
Sev is offline   Reply With Quote
Old 05-20-2018, 06:36 PM   #9
glenB
Drives: Chevrolet Camaro SS
Totally wrong
1. The engine doesn't need back pressure
2. Back pressure kills power
3. The AFM vales are to reduce the vibrations and the odd sound caused by the 4 cyl. operation only
glenB is offline   Reply With Quote
Old 05-21-2018, 06:55 AM   #10
mdhopt36
"It gives you a headache after a few minutes."
Ever been in a Cherokee, or Cessna? No problem---as long as you don't have much to say without the muffs!
Doesn't bother me one bit.
Old 05-21-2018, 07:02 AM   #11
mdhopt36
"Fuse 51"
In the fuse box, the cover on mine has the fuses numbered, but the fuse box itself, -NO- fuse is actually numbered, and the fuse schematic looks to me to be deliberately scrambled. I worked with an electrical engineer, and that would never have passed on his blueprints.
I'm wondering if it was a deliberate attempt to prevent the casual yanking of the fuse?
My car is only 2 months old.
Old 05-21-2018, 08:12 AM   #12
Gen6_1Le
Gen6_1Le's Avatar
Originally Posted by glenB View Post
Totally wrong
Don’t matter what back pressure does or don’t do ,it’s in the tune from the factory mess with it and it has its effect. Put long tube headers with straight 3 inch pipes on it without a tune and see if it was worth it .
Old 05-24-2018, 08:00 AM   #13
mdhopt36
"Fuse 51"
Well, went to the local dealer, and the salesman helped me locate the right fuse. Print on the cover was throwing me off.
Now, she purrs all the time!
Old 05-24-2018, 08:01 AM   #14
mdhopt36
(What I actually pulled before, was the HORN fuse!)
