Old 03-02-2016, 04:34 PM   #29
Blackdevil77
Blackdevil77's Avatar
Drives: 2008 Pontiac G8 GT, Shelby GT500
Originally Posted by ocautomotive View Post
No it does not. Even if it did, nobody on this thread with a M6 is saying they can hear it, so it has to be an abnormal sound.
Originally Posted by Eric SS View Post
I'm pretty sure the M6 still has the AFM hardware, it's just tuned out. I could be wrong but I think that has been the consensus.
Yeah that's what I thought. Why spend the extra money to change the hardware on the engine depending on what transmission the car has? Much easier and cheaper to just turn it off via tune. If that's the case, which I believe it is, that AFM hardware is still being used (lifters etc).
Blackdevil77 is offline   Reply With Quote
Old 03-02-2016, 04:40 PM   #30
Modshack
Modshack's Avatar
Drives: 2SS, Hyper Blue
Mine doesn't. On the C7 Corvette there was a second set of valves in the exhaust system that activated to reduce Noise and resonance. Not sure of the A8 Camaro has these, but the M6 does not..The Cylinder disconnect is likely handled Via software and VVT..
You can see the valves just above the mufflers in this C7 cutaway..
Steve
Hyper Blue 2SS, 6M, NPP, Sunroof, Nav
Modshack is offline   Reply With Quote
Old 03-02-2016, 05:21 PM   #31
Jeb114
Jeb114's Avatar
Drives: 2021 300
Sounds normal, these direct injection engines have high pressure fuel pumps and you are going to here the injectors more in these cars.
Jeb114 is offline   Reply With Quote
Old 03-02-2016, 07:01 PM   #32
ocautomotive
Drives: 2017 ZL1 and 2018 SS 1LE
Dealer said it is normal but they want to take the belts and the intake manifold off to check everything though....It seems wierd that they say it is normal but wants to check, but I am glad they are doing so.
ocautomotive is offline   Reply With Quote
Old 06-23-2017, 10:39 PM   #33
EarthToGreg
EarthToGreg's Avatar
Drives: 2017 Krypton Green 2SS
Originally Posted by BadBillyJack View Post
sounds to me like it falls under this Technical Bulletin
#15-NA-040: Rattle or Flutter Noise When Switching Between V4 and V8 Operating Modes - Some customers may comment on a rattle noise at 48 km/h (30 mph) to 64 km/h (40 mph) when the engine is switching between V4 and V8 and/or notice fluid leaking from the bellow on top of the tensioner.
Correction
- If diagnosis in SI does not isolate the noise, replace the drive belt tensioner.
After some testing, I'm pretty sure that this is what my car is experiencing. I only notice the noise when it's in V4, usually between 30-40mph.
My question is, what exactly does a Technical Bulletin mean I should do? Take it. Ack to the dealership?
EarthToGreg is offline   Reply With Quote
Old 06-24-2017, 02:50 AM   #34
elementaltoad
elementaltoad's Avatar
I can't say I've paid particular attention to noises on decel at around 3k RPM, but as loud as that sounds on video, I would say it's not normal. I have a M6 and haven't heard that yet.
Definitely update us and let us know what it is if they find anything.
2016 Camaro 2SS Garnet Red 6 Speed
1990 Firebird Formula WS6
1989 Firbird Formula 350 WS6, LS Swapped
elementaltoad is offline   Reply With Quote
Old 02-20-2018, 07:54 AM   #35
Reaper333
Drives: 2016 Camaro 2SS Black..
I have my car in right now for this exact issue. They are replacing the tensioner. So who knows if it will fix the issue. But it is definitely not normal and is extremely annoying. Even worse if your going up a hill.
Reaper333 is offline   Reply With Quote
Old 02-20-2018, 09:17 AM   #36
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Sorry I can't hear any strange noise either. I pulled the foam out of the sound tube, pulled the exhaust fuse and set my NPP to track mode on my SS. I do hear some air intake noise when shifting and running hard sometimes. I would keep tabs on it and if it gets worse take it back to the dealer and let them check it again. Good luck!
Old 02-20-2018, 09:19 AM   #37
LT4Greg
LT4Greg's Avatar
And I do have a Cold Air Inductions CAI system so mine will not have a stock airbox sound.
Old 05-24-2018, 01:17 PM   #38
squish72
Drives: 2016 2SS 8AT
I didnt want to bring a corpse from the grave but I had this issue and feel I figured it out and might be able to help anyone else in the future.
Little back story, I bought a low millage 2016 2SS and it already had a CAI intake on it. On the 240 mile drive home I kept hearing this noise and was worried I bought a junk car luckily that was not the case. I came across a thread talking about removing the foam in the sound tube, since it was a
quick easy job I decided to try it and if I didnt like it I could easily return it.
Well the sound I was hearing actually got WAY louder and was exactly what I
must have been hearing. I reinstalled the foam plug and I traced the tube to the firewall above the throttle pedal and inserted a square chunk of memory foam I had. The sound now is gone and I can actually hear the true sounds of the wonderful LT1 and not some fake rattle that the sound tube was filling the cabin with.
squish72 is offline   Reply With Quote
Old 07-11-2018, 04:38 PM   #39
W16camaro2SS
W16camaro2SS's Avatar
Drives: 2016 camaro 2ss
Has anyones car make this noise before? https://youtu.be/iwVLbkIp-uA
W16camaro2SS is offline   Reply With Quote
Old 07-11-2018, 04:46 PM   #40
squish72
Very hard to tell in the video where the sound is coming from. Almost sounds like a heat shield rattle from what I can tell. Check the all heat shields down the exhaust system first.
Old 07-11-2018, 06:25 PM   #41
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Yep, loose heat shield.
Old 09-03-2020, 10:36 PM   #42
Lifetaken
Lifetaken's Avatar
Drives: 2018 SS Camaro 1LE
Sorry for reviving this old thread but did you ever get this fixed with the dealer replacing the belts and such, or is this in fact normal? Mine makes this exact noise in this exact RPM range as well.
Lifetaken is offline   Reply With Quote
