02-19-2019, 06:32 AM | #1 |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
2019 PDR - Anyone notice any difference?
I know with the previous iterations - there is so much wind buffeting above 88mph that it makes the video unwatchable.
Curious as to whether anyone here has taken their cars to the track or experienced the PDR quality (in Mexico)? |
02-19-2019, 07:36 PM | #2 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
The wind noise seems to be variable from car to car. It thankfully isn't bad on mine even up to 150+ MPH. (2018 Car)
https://www.instagram.com/p/BtuW2EaH...on_share_sheet
02-19-2019, 09:48 PM | #3 |
Drives: 2019 ZL1 1LE Join Date: Jan 2019
That was a lot of wind noise IMO. Too bad the mic isn't mounted somewhere else, it'd be really nice to hear the engine and exhaust instead of the wind. I haven't used mine but I'm going to throw a memory card in there and hit the freeway tomorrow. Will let you know if there's any difference between the '18 and the '19.
02-20-2019, 08:39 PM | #4 | |
aka BeastZL1
02-24-2019, 01:58 AM | #5 |
Drives: 2018 Summit White Camaro SS 1LE Join Date: Oct 2017
I have an 18 1LE with PDR, what are you all purchasing for SD Cards?
Is there a brand or specific specs that I should be looking for? Thx, |
04-03-2019, 10:25 AM | #6 |
Anyone take a 2019 on track and report back? Curious if the wind buffeting over 85mph is gone with the 2019.
#SAVETHEMANUALS
04-04-2019, 05:34 AM | #7 | |
Last edited by DeadSpider; 04-04-2019 at 12:29 PM. Reason: Embedded youtube links |
04-29-2019, 02:22 PM | #8 | |
Card format = FAT32 Not all cards are formatted to FAT32, so have to check that on a PC first.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
05-05-2019, 07:59 PM | #9 |
Drives: 2018 ZL1 Camaro Join Date: Mar 2019
you can use larger than 32 Gb they just say that because windows fat32 max size is 32. You can use a Mac or third party to format larger SD card Fat32
The mic is actually on the bottom of the camera. If you look at the cover that is behind the rear view mirror there is a small hole that is for the mic. If you are having issues I suppose you could try to cover that hole and see if it cuts the noise issue. |
