Old 01-26-2019, 10:02 PM   #1
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Looking for 8L90 after market replacement
Can someone please refer me to any aftermarket 8 Speed Automatic Transmissions that are not specifically in any way related to the 8L90 trans?
Links in particular if possible please.
Thanks!
Old 01-26-2019, 10:08 PM   #2
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
ZF.. they come in lots of flavors
ing for grip.
http://www.motorsportsne.com/
Old 01-28-2019, 07:06 AM   #3
Raptor Jesus
Drives: Camaro
Thanks!
There is no other 8 speed auto you can swap in the car if that is your question. People will reply and say "anything is possible" but the answer is no. ZF is an awesome transmission but will not work with the Camaros TCM and the physical size won't work. No you can't "make it work" no you can't "figure out a TCM" no. no. no.
Raptor Jesus is offline   Reply With Quote
Old 01-28-2019, 08:40 AM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
you could probably open yourself up to some options if you want to go to a 2 speed, 3 speed, 4 speed, or 6 speed auto trans
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 01-28-2019, 09:37 AM   #5
Raptor Jesus
Drives: Camaro
Even the well known and knowledgeable tuners who have TH400 swapped these cars still can not get it to work 100% with the ECU and it will need to be manually shifted. So it's still not an option.
Old 01-28-2019, 09:45 AM   #6
danhr
BAMF SS
danhr's Avatar
who puts a th400 in a car and doesn't put a manual valve body in it? I don't even know the last time I saw an actual TH400 without a manual valve body. lol
and who would swap transmissions and not ditch the factory ECM/TCM? Hell, if Holley would offer 8l80 support in the dominator, I would be going to that right now, and I'm just a bolt on car. lol
Stock Longblock
Old 01-28-2019, 09:59 AM   #7
parish8
Drives: 17 SS a8
I would. Maybe not a 400 but if I did a 4l80 it would be computer controlled and still have lock up. Even if I did a 400 it would be computer shifted while drag racing.
Old 01-28-2019, 10:04 AM   #8
parish8
Drives: 17 SS a8
That being said I am sticking with the 8sp for awhile. It is a pretty stout unit.
Old 01-28-2019, 02:12 PM   #9
Raptor Jesus
Drives: Camaro
This is why I said no from the beginning. It went from a simple transmission swap to a manual valve body trans with not a single body control function working anymore. Basically a full on drag only car. Who would swap a trans and not keep the ECM? Um.. basically anyone that wanted to use any other function of the car.
Any car you can rip out all the electronics and throw a stand alone with a digital cluster and run any powertrain you want. That's not a solution to the OP's question.
Old 01-28-2019, 03:11 PM   #10
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Are you concerned about the recurring shudder issues? If yes then do you need to replace the entire transmission or just the torque converter? That seems to be the weak link. I haven't seen many complaints from people that programmed the TCM to remove slip and/or replaced the torque converter. It seems like the transmission itself is OK up to moderate power levels.
Old 01-28-2019, 06:34 PM   #11
danhr
BAMF SS
danhr's Avatar
What functions would you lose by not using the factory ecm/tcm?
I think parish still uses the factory gauges with his megasquirt setup?
There are standalone controllers for transmissions?
Stock Longblock
Old 01-28-2019, 06:45 PM   #12
parish8
Drives: 17 SS a8
I still have the factory ecm. I see no reason to remove it. No idea what all it is still doing.
Old 01-28-2019, 06:46 PM   #13
parish8
Drives: 17 SS a8
By moderate you mean 1000+hp? Then yes.
Old 01-28-2019, 06:48 PM   #14
Raptor Jesus
Drives: Camaro
Climate control, display, radio, cluster, door locks, windows, seats, wipers, srs, abs, vsa, electric power steering... basically anything controlled by the BCM which receives signals from the factor ECM. Take the tcm out and the ECM will not function and no you can’t program the ECM to work without it. Megasquirt in that application is not a stand alone and it works in conjunction with the factory ECM and overrides the signals the ECM sees.
