12-01-2018, 12:23 PM | #15 |
Drives: Black Join Date: Jan 2017
Would be pretty cool if we just discovered the ultimate budget bolt on for the lt1. The msd isnt cheap and l86 intake is dirt cheap.
12-01-2018, 12:34 PM | #16 |
Drives: 2016 2SS 8AT Join Date: May 2018
Yeah it's cheap enough to try. I'm worried about how it is at 6500rpm. Maybe porting can change that.
12-01-2018, 12:42 PM | #17 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
Oh, that’s perfectly fine. I think that if it fits, it would be beneficial to port it before I threw it on my setup. Do you know what throttle bodies it can accept? If the 95mm fits on it, that’s even better.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
12-01-2018, 12:48 PM | #18 |
From what I've seen they run the same 87mm throttle body so same rules apply to it as the stock lt1 intake
Edit: wanted to make clear that the 95 will fit after modifying the TB or using an adapter. Last edited by squish72; 12-01-2018 at 01:50 PM. |
12-01-2018, 12:55 PM | #19 |
The guy in that thread I posted said he’s taking his msd off and throwing on a ported l86 intake and 95mm TB, so I’d assume so
12-01-2018, 01:25 PM | #20 |
Drives: 2017 LT1 Join Date: May 2018
No the L86 will not accept the 95 in stock form.
12-01-2018, 02:54 PM | #21 |
I’m having a rough time seeing where you put the measuring tape on the engine. Is that bolt one of the valve cover bolts? Our hardware is different and throwing me
12-01-2018, 04:01 PM | #22 |
I can take measurements on Monday as my intake is still in the box and doesn't have the upper cover/insulation on it either.
12-01-2018, 05:02 PM | #23 |
Beautiful, I have a extra LT1 manifold on the bench here as well so we can get some good dimensions
12-01-2018, 05:27 PM | #24 |
Why is the jonA results so different?
12-01-2018, 07:48 PM | #25 | |
Drives: SS 6 speed of course Join Date: Jan 2016
intake, headers, CAI, TB, exhaust hood scoop, tune would all fall outside of factory long block. I really like the way the manifold looks, but the long runners will hamper resonate efficiency on the top end. So anything bigger then stock cam I can't see it.
12-01-2018, 08:39 PM | #26 | |
I never said bolt on haha
12-01-2018, 09:33 PM | #27 |
I must have dreamed it LOL
So for a Procharger, would this and a stock TB be an optimal setup, the long runner will boost the mid range torque, and the Procharger can put out more boost on the top end then the factory engine can take...
12-02-2018, 11:07 AM | #28 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2018
Do both have the same supporting mods. Looks like the red has flex fuel and headers according to the legend.
