Old 12-10-2018, 10:52 AM   #43
Josh/AWE
Josh/AWE's Avatar
Drives: 1LE
Originally Posted by Can'tHave2MuchHP View Post
Actually, exhaust is quietest brand new and will get louder over time.
Quite the contrary, my friend. This is is not applicable to our configurations. They are loudest when first installed.
  • Our break-in period is 800-1000 miles
  • Carbon buildup alone takes the edge off exhaust tones
  • Our systems that have resonators/mufflers packed with our special blend of acoustic material (read: not applicable to our 180 Technology resonators as they do not have packing in them) refine themselves significantly because of the type of packing we use. Typical packing material breaks down and shoots out the back after being beaten by exhaust pulses for a while. Ours does not -- it's a single strand fiber built for durability. It does everything but get weak and break down
Josh/AWE is offline   Reply With Quote
Old 12-10-2018, 10:59 AM   #44
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
  • Our systems that have resonators/muffler packed with our special blend of acoustic material (read: not applicable to our 180 Technology resonators as they do not have packing in them) refine themselves significantly because of the type of packing we use. Typical packing material breaks down and shoots our the back after being beaten by exhaust pulses for a while. Ours does not -- it's a single strand fiber built for durability. It does everything but get weak and break down
Interesting. That’s new to me. Every exhaust I’ve ever heard gets louder as it breaks in and the baffling cannot do its job as efficiently as it once could. The change isn’t huge but it is noticeable back to back.
Old 12-10-2018, 11:02 AM   #45
joe944
joe944's Avatar
Drives: 18' A10 ZL1 , 18' F150, 04' MSM
Interesting. I'll try to see what mine does after I get it installed next weekend. Stoked to hear it in person!
joe944 is offline   Reply With Quote
Old 12-10-2018, 11:57 AM   #46
Josh/AWE
Josh/AWE's Avatar
Drives: 1LE
The more ya know
Also, our systems don't have baffles.
Old 12-11-2018, 01:59 PM   #47
XXX ZL1
XXX ZL1's Avatar
Drives: 2023 ZL1 M6
I wonder if tuning the torque tables and driver demand tables will correct the closing tb.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, Roto Fab Big Gulp, NW 103, ARH 2
inch LT's, Stainless Works NPP
Signature Forged 20x10.5/20x11.5, BMR springs,
BMR Cradle lockout, AAD Billet Control/Trailing arms
2023 Vivid Orange ZL1 M6 - sold
2019 Riverside Blue ZL1 A10 - sold
XXX ZL1 is offline   Reply With Quote
Old 02-22-2019, 12:49 PM   #48
Torquem
Bannable
Torquem's Avatar
Drives: 2017 Camaro ZL1
Well. This is weird. Finally got a day decent enough to take it to local shop. It's definitely leaking here alright. It's barely in the cat pipe. It almost looks as if the plp is not long enough. We are going to try and loosen pipes behind it and make up some area, but I dont think it will be enough. This is truly weird.
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic
Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's
Torquem is offline   Reply With Quote
Old 02-22-2019, 12:53 PM   #49
Carbon build up around fittings is sometimes very normal. You probably see some of that further back on connections as well.
Old 02-22-2019, 12:58 PM   #50
staples87
With those types of clamps it can be, however the problem is if the 02 sensors are very sensitive then you don't want any carbon build up / leaks around that area, otherwise a CEL is inevitable.
The only option may be to use a high temp exhaust sealant.
staples87 is offline   Reply With Quote
Old 02-22-2019, 01:12 PM   #51
Torquem
Bannable
Torquem's Avatar
The other carbon I am not concerned about. The carbon up front is because the pipe is so far out that the pinch cutout is exposed. I'm going to try moving pipes around to tighten up tolerances. Hopefully the plp is long enough.
Old 02-22-2019, 05:32 PM   #52
Canadian ZL1
Canadian ZL1's Avatar
Drives: 2017 ZL1, 1995 Trans Am
Originally Posted by staples87 View Post
Best course of action in finding leaks if there isn't carbon build up... water with a little bit of dish soap in a spray bottle, sprayed around the clamps to see if it bubbles. If you still can't find the leak then an automotive stethoscope as a last resort.
AWE provides a paste. You should contact them directly and that should solve your problem. I ordered the exhaust and had them send me the paste just in case. Can't wait to install in April 2019.
_____________________
'17 ZL1 HBM|A10|NAV|PDR|CFW Hood|Sunroof
Canadian ZL1 is offline   Reply With Quote
Old 02-22-2019, 09:55 PM   #53
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Where did you order from and which system?
Old 02-22-2019, 10:01 PM   #54
Canadian ZL1
Euro Sport Tuning in Oakville.
I went with...
AWE Touring Edition Cat-back Exhaust for ZL1 - Non-Resonated - Chrome Silver Tips (Quad Outlet)
Old 02-22-2019, 10:09 PM   #55
Scottyz
Scottyz's Avatar
I went with...
Check your pms
