03-30-2018, 09:56 PM | #57 |
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel Join Date: Oct 2017
03-30-2018, 10:00 PM | #58 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
04-01-2018, 11:29 PM | #59 |
2018 1LE, NASA Instructor
Drives: 2018 Camaro SS 1LE Join Date: Jan 2018
What is the fuel cut out on 2018 SS 1LE in stock form? 6,500? 6,600? 6,750?
Sorry to ask, my car in in break in period, so I can't really test it without going to GM jail. |
04-01-2018, 11:36 PM | #60 |
04-08-2018, 09:45 PM | #61 |
Drives: 1LE Join Date: Sep 2017
I mechanically over revved to ~7200 and this happened!??
04-08-2018, 10:00 PM | #62 |
Wow - now we know what a money shift looks like!
Best of luck on the rebuild.
04-08-2018, 10:34 PM | #63 |
Nicky Bobby, i think the key point is you were over reving lap after lap - every minute - pretty much
If this motor was good for 7000+rpm then this would be its redline... |
04-09-2018, 06:30 AM | #64 |
Drives: '18 1SS 1LE Join Date: Sep 2017
If the head snaps off your intake valve at speed, your piston will disappear. No piston to control connecting rod, and rod will leave block.
Valve springs have a rating, when that is exceeded, the spring is now compromised. Once a spring fails, the valve is free to meet the piston. Internal combustion. |
04-09-2018, 06:42 AM | #65 |
You’ll have to put in heavy duty valve springs if you want to keep doing that with the new motor.
The trade off wth them is they need to be warmed up each time, as they are more brittle when cold. Edit: even with valve springs 7200 rpm is pushing it. Unless you know what you’re doing I wouldn’t go much more than 6900 Last edited by 6spdhyperblue; 04-09-2018 at 09:26 AM. |
04-09-2018, 09:12 AM | #66 |
Drives: 1LEs Join Date: May 2009
...and get rid of the AFM lifters for regular ones...
04-09-2018, 09:17 AM | #67 |
Drives: 2004 Z06, 2017 1LE Join Date: May 2017
Once or twice, you probably wouldn't have had a problem. That video indicates it was happening multiple times every lap. Routinely exceed the operating parameters of any mechanical piece of equipment, and you should expect eventual failure.
04-09-2018, 09:29 AM | #68 |
At the end of the day it’s a torque focused motor with power all mid-rpm range. There’s not much going on above 6400, I would just keep the rev la in the meat of the powerband
04-09-2018, 12:08 PM | #69 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
Yea, I really don't know what the point of over-revving this kind of engine would be. Even if you're trying to keep the car in the power band for the next gear, it's pointless because of the really broad powerband. It's not a GT350 that actually *needs* to keep the revs up high to stay in the power.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
04-09-2018, 01:16 PM | #70 |
@SS_1LE
Drives: 2017 SS 1LE Join Date: Mar 2017
As others have said why would you even raise the stock limiter? These motors aren't continuing to build HP over 62-6400RPM. Keeping the motor safe is more important than being able to get a couple extra MPH out of each gear.
17' Camaro SS 1LE | PDR | Summit White
Borla S-Type Axleback | Mishimoto Catch Can | LED Sidemarkers | ZL1addons DRGs | Michelin MPS4S |
