Old 09-27-2017, 10:49 PM   #1
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | 18 F150
LT4 conversion parts list (with part numbers) - Need some confirmations
Looking to do the LT4 conversion and I've compiled a list... Looking for some help to confirm part numbers
Please note that the list assumes having a blower already (I do, from a 15 Z06)
Parts from ADM that are NOT OEM...
  • Modded LT4 Valley Cover
  • LT1>LT4 Adapter plates
Will probably just buy a black silicone intake elbow
OEM parts list...
  • LT4 Idler Pulley/Tensioner - Need #s
  • InterCOOLER PUMP - GM (13597902)
  • OEM LT4 Belts 12643219 (ac belt) + 12643218 (serp)
  • OEM Oil cooler pipe - 12656725 or 12678753?
  • OEM LT4 Harmonic Balancer - 12671006 or 12668109?
  • OEM ZL1 Heatexchanger - 22879421?
  • OEM Heat Exchanger Cooler Lines - Need #s
  • OEM ZL1 Evap purge line - Need #s
  • OEM ZL1 elbow fresh air inlet tube for Pcv - 12670877?
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!)
'18 F150 Platinum Powerstroke diesel
'22 Kia EV6 First Edition
'18 RS3 (1 of 2) Cumulus Blue
'24 911 T (ordered)
Formers...
'19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 09-28-2017, 05:27 AM   #2
ADM PERFORMANCE
Drives: Anything I want
Do you have a blower?
You need a blower, If you don't have the correct LT4 blower it will not work straight out of the box.
Here is what I would suggest - Complete Install kit if you already have a blower-
https://lsa-conversion-store.myshopi...ower-no-blower
Or
https://lsa-conversion-store.myshopi...ger-kit-625-hp
ADM PERFORMANCE is offline   Reply With Quote
Old 09-28-2017, 10:14 AM   #3
RideZX6R
RideZX6R's Avatar
Updated original post, this is a list for those who have already purchased a blower
-Seven
'24 911 T (ordered)
Formers...
Old 02-16-2019, 02:40 PM   #4
gflo29
Drives: 2017 Red Hot ZL1 A10
Is this a complete parts list? Everything you needed??
gflo29 is offline   Reply With Quote
Old 02-24-2019, 12:05 AM   #5
Drsagacity
Drsagacity's Avatar
OEM parts list...
@ridezx6, might want to include the ATI lower pulley instead of the stock LT4 pulley. From what I can tell, this setup benefits much more from using the lower pulley to increase boost and leaving the upper pulley stock.
I have a buddy running 740whp by running stock upper and 15% overdrive on lower.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 02-24-2019, 12:35 AM   #6
RideZX6R
RideZX6R's Avatar
This thread is over a year old sir.
Decided against even going with LT4 blower personally
-Seven
'24 911 T (ordered)
Formers...
Old 02-24-2019, 01:08 AM   #7
Drsagacity
Drsagacity's Avatar
didn’t notice that. I was looking at what is required for the lt4 blower setup...doing some research.
TBD performance
