Old 12-26-2018, 04:20 PM   #155
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
Originally Posted by parish8 View Post
I do hope to be near the front of the pack come spring. I just need to make time to get to the track a lot more. Once things start working I am not going to hold back.
I am late to the party but will be trying to have a similar trap..
I need to talk to you when you get a chance about some concerns with my PFI project this winter.
happy holidays
hitmix300 is offline   Reply With Quote
Old 12-26-2018, 04:26 PM   #156
parish8
Drives: 17 SS a8
happy holidays
What are your concerns?
Old 12-26-2018, 05:10 PM   #157
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I can't wait to see the wicked pass you make at some point, it will be a wake up for all of us.
Old 01-29-2019, 01:37 PM   #158
MaxPower
Long Member
MaxPower's Avatar
Drives: 2009 G8 GTT
Somehow came upon this thread of yours - I modeled my first G8 kit right from your original G8 build. Your latest build is impressive as usual!
Second go at it with my G8 (sold car, bought it back), on Precision turbos... and they're pushing oil past the front seals it seems, even with drawing as much venting off the valve covers and valley...
What's the feed/return setup you've got on them? Single -3an then split to each? How big are your return lines?
I use a billet return adapter to -10 into a catch bin that then gets pulled by a scavenge pump... Not sure it's working as well as it could.
Good luck this upcoming spring!
2009 G8 GT. TwinTurbo'd by ME.
Twin Precision 5976e
E85, Stock Cam, Stock Stall.
10.88 @ 137mph w/ 1.83 60'
MaxPower is offline   Reply With Quote
Old 01-29-2019, 02:00 PM   #159
parish8
Drives: 17 SS a8
I use -4 to the turbs and -6 return. I have oil restrictions in the turbo oil inlets. I also have a 30sec time delay off relay so the pump runs after the car is shut off. I found you need to keep the return pump as low as you can and the pre pump line as short as you can. Also too big of a line is bad for suction. The oil gets pretty thin and can’t climb a fat hose with suction.
Old 01-30-2019, 02:05 PM   #160
MaxPower
Long Member
MaxPower's Avatar
Drives: 2009 G8 GTT
What size restriction did you use? Those 6266's BB or Journal?
Looks like I'll be moving the pump and switching up the lines a bit. Always thought a larger return line to allow free"er" flow out of the housings.
Thanks a million!
Old 01-30-2019, 02:25 PM   #161
parish8
Drives: 17 SS a8
Journal. Something like this https://www.ebay.com/itm/060-AN-4AN-...0AAOSwuqdaquSS
I think your set up from the turbos yo the little box is ok. Large lines for gravity drain are good. From that box to your pump needs to be fairly small, flat and not very long. Post pump you can run 20+’ if you want. Still a small hose.
I had some issues too. My pump head was about 10” higher than the turbo drains and about 3’ away. I got that down to ~2” above and 2.5’ away and my issues went away.
Old 01-30-2019, 02:28 PM   #162
parish8
Drives: 17 SS a8
Oh yeah, I also put a 1-2psi check valve in the turbo feed line down near the turbos to prevent gravity draining into the turbos over night. I don’t know how much of what I did was required but having a car belching smoke is embarrassing and stinky.
Old 02-01-2019, 08:24 AM   #163
MaxPower
Long Member
MaxPower's Avatar
Drives: 2009 G8 GTT
Awesome! I swear these little gotchas need to be a sticky on every turbo forum out there for low/mid-mount setups!
Thanks a ton again! Sounds like this will all take care of the oil problems I've got
Old 02-02-2019, 12:41 PM   #164
laynlo15
laynlo15's Avatar
Holy crap its max power from st louis, my old g8 buddy. Miss my Maggie G8GT. (locrzn)
Old 02-06-2019, 09:50 AM   #165
MaxPower
Long Member
MaxPower's Avatar
Drives: 2009 G8 GTT
Old 02-07-2019, 02:32 PM   #166
laynlo15
laynlo15's Avatar
Max hopefully we will get some test and tune next month at Gateway.
Old 03-28-2019, 09:47 AM   #167
MaxPower
Long Member
MaxPower's Avatar
Drives: 2009 G8 GTT
Any updates on the beast?
Old 05-15-2019, 09:44 AM   #168
chross12
chross12's Avatar
Drives: 2016 ss whipple,rotofab,A8,magride
parish8 WOW i haven't posted in a while and i noticed 1000rwhp!!! How dare you put that massive amount of hp down. haha Congratulations man the installation looks really nice. Did you go for a solid back axle deal? or how the hell do you get it to launch???
chross12 is offline   Reply With Quote
