06-06-2018, 08:46 AM | #43 | |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
I also wonder if these engine dynos they are doing do not likely match the sae protocol. Certain temp. Full accessory load. Full factory exhaust (well in this case full exhaust as in whatever the car is running). I’ve seen a stock ls3 make something like 500 hp on an engine dyno with open headers and no accessories. If they are basing rwhp loss figures from a higher than normal engine dyno in the first place perceived drivetrain loss will be inflated as well |
06-06-2018, 08:49 AM | #44 | |
Drives: 2013 SS Join Date: May 2013
06-06-2018, 08:56 AM | #45 |
Are they making 500 with full factory exhaust and accessories load ? I’ve seen similar figures with an ls3 on an engine dyno. Same with the ls1. 418 hp open header no accessories
IMO an open header and no accessory test is more like the gross hp ratings if the 60s. Your procedure does not match the SAE protocol that found 455-460 hp. Or maybe I’m off here would like to know more... |
06-06-2018, 08:56 AM | #46 | |
Drives: 2016 2SS Join Date: Jul 2016
My thoughts about the discrepancies is that the Industry standard is SAE for Manufactures. So as the motor will sit in the car with all the accessories and emissions and all of that. Most engine dyno's by "shops" are done with an EWP and not much attached to the motor like 4 cats and all of that junk. So there has to be a difference in numbers from the differences in testing procedures.
06-06-2018, 08:59 AM | #47 |
Yup, weight, weather, and mph are the three main determining factors at the track. Then car set up.
06-06-2018, 09:31 AM | #48 | |
2016 NFG 1SS A8
06-06-2018, 09:58 AM | #49 | |
06-06-2018, 10:01 AM | #50 | |
Test on the engine dyno were done with cats 4 on the camaro LT and 2 on the C7 reason why those would see over 500hp.
06-06-2018, 10:07 AM | #51 | |
Ac Power steering delete, shorter belt air filter removal, factory catback exhaust removal and that's how we used to get LS1 Fbodys in the mid 12s on a DR
06-06-2018, 10:58 AM | #52 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
Let me ask a question to the cam experts. While I am not sure this is true for off the shelf cams, if you are custom grinding an NA cam for an m6 vs a8 for 1/8 or 1/4 mile racing, what cam specs would be different for the M6 vs a8?
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
06-06-2018, 11:05 AM | #53 | |
Drives: 2011 2SS/RS & 2017 1SS Join Date: Apr 2011
Not sure if you are aware but Zach Bowman 10.82 @130MPH (Current Fastest M6 NA 6th Gen) is running this exact same GPI Heads/Cam package....
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE Built/Tuned by Me 2017 Chevrolet Camaro 1SS Auto 9.29 @144.57mph ALL MOTOR SBE #TEAMGPI Gwatney Performance Innovation |
06-06-2018, 11:52 AM | #54 |
I thought that might be the case, but am curious if there is an optimal solution cam spec wise depending on your transmission type.
06-06-2018, 01:07 PM | #55 |
Drives: My Dad's car is a '16 1SS 6MT Join Date: Jul 2016
Why didn't you spin it higher?
06-06-2018, 02:15 PM | #56 |
It was spun to 7K. Why spin it any higher on the dyno? Although I do shift higher at the track.... LMAO
