11-21-2022, 10:08 PM | #1 |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
2023 Wheels, Need Centercaps
Need help with centercaps. Just picked up these 20x9.5s off of a 23 SS. The guy kept the centercaps. I’d like to get the “SS” centercaps vs the bow ties. Amazon, eBay, etc have the “SS” centercaps listed as “2016-18” or “2016-2020”.
I’m not up on my 6th gen wheels, but last I knew, centercaps were all interchangeable between the 6th gen wheels. Am I wrong? I’d appreciate your input. Thank you.
"Make yourself sheep and the wolves will eat you"
11-22-2022, 12:12 AM | #2 | |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
11-22-2022, 07:13 AM | #3 |
Thank you much. Appreciate the help.
11-22-2022, 09:02 AM | #4 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I believe that all the 6gen center caps are the same diameter I just can't quote that number...it's usually in mm/millimeters. When I put on MRR wheels those took 5th gen center caps of 59mm. The 6th gen caps wouldn't be able to transfer over.
11-22-2022, 09:33 AM | #5 |
Thank you. I know the 5th and 6th centercaps are not interchangeable, the 6th gen is a slightly larger diameter. But it seems I’m ok with any 6th gen centercap.
