05-30-2021, 06:35 PM | #99 |
Drives: '23 Hyundai Kona N, '24 VW GTI Join Date: Aug 2019
05-30-2021, 07:11 PM | #100 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
05-31-2021, 07:27 PM | #101 | |
Drives: 2020 Camaro SS 1LE Join Date: Apr 2020
Any yes, this IS aggressive! |
05-31-2021, 11:46 PM | #102 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Day was about 55-60F, sunny, dry day. Surface is some weird blacktop. I used a tire pyrometer and digital tire pressure gauge (Longacre stuff). I started at 29.6 psi cold and ended up adding pressure after two or three test runs at that setting. Hot pressure coming in from the runs would only get to about 32psi and the tire temps showed the same temp middle and inside with the outsides being about 2-3F cooler (front and rear). My notes indicate that running at those pressures the tires were not coming in quickly [to grip] and the rear was squirrely. I actually ended up adding pressure the rest of my trials. I can't comment what the true "cold" psi is (I can go check them in the garage as I haven't touched them), but the pre-run psi I ended at was around 34psi front, with the rear having just a touch less psi and rendering a 2-3F spread across the outside, center and inside of the tread (i.e. 92-94-97). My notes indicate the tires came in a lot quicker and the car had a good balance of grip. Times dropped at least 1-second. But, again, I'm on 275/315 tires on 10"/11" wheels, maybe your ambient temp was a lot hotter and/or your track surface was a lot more grippy. |
05-31-2021, 11:57 PM | #103 |
Also... I ran the OEM SC3 (20" setup) that same day, same course. Playing with the tire pressures as well. I will say this: the SC3 can run a similar time as the RT660, but they need heat in them: the RT660 for sure felt to come in way quicker than the SC3 (I noted that the RT660 comes in, for the first run, after just a few maneuvers putting some slip into them, while the SC3 seemed to need almost 1/3 of the course to feel as confident). If autocross is the goal, the RT660 is the way to go over the SC3.
I am going to bring the RT660's to TT Nats with me and run them for a practice session to see how they do. I've read a few others notes on them on track, including Strano's notes, but I want to try them myself. Maybe I'll end up running them for the event if they seem to show some kind of advantage over the SC3 (which I love as a 200tw track tire). We'll see. |
06-01-2021, 07:46 AM | #104 | |
While this may not lead to tears in autox, going WOT thru the esses at the Glen may lead to different outcomes, given extreme loads. Note what Mountain has done rim vs tire sizes and imo this is the way to get the most out of a tire: "not the other way around". All pro race cars maximize rim size, to ensure stiffest side wall possible and hence the most feedback and responsiveness possible from the tires. Going the other way will reduce both and hence it makes zero sense for performance. Sure, an A7 will deliver better pace over streets even in a sub optimal set up, buy why leave pace on the table and push tires outside their safety design specs? Lastly, this is of particular importance for fronts, as they do a lot more work under braking and cornering, usually dealing with much higher loads. Anyhow, you asked the question, which suggests you either didn't know, or simply sought validation from others to "justify" your decision. If the latter: be careful, as we don't all track our cars at the same pace, the same venues, or at the same limits. Just my 2 cents, that's all. Cheers! |
06-01-2021, 11:19 AM | #105 | |
06-01-2021, 01:45 PM | #106 | |
06-01-2021, 02:25 PM | #107 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
If we're looking at 305s on 10" wide rims that's close. For Michelin PS4S recommended width is 10.5 - 11.5".
06-01-2021, 04:00 PM | #108 |
06-01-2021, 08:35 PM | #109 | |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
I am sure there is no safety concern. People have been mounting 305/30s on 19x10s with our cars since the first 6th-gen 1LEs came out. I am sure there will be a difference in feel. One question will be how the bigger front tires wear: will they do anything strange. Again, that has not been a problem on the RE71 or Rival S 305 fitment; so probably not, but every tire model is different. They may end up wearing better simply because of their higher load rating. In terms of the stopwatch, it may very well end up being a wash: more contact patch offset by bigger diameters. In that case, it would come down to feel. Two indisputable advantages to the 275s: they are cheaper and one of the fits into the Camaro trunk a lot more easily than the 305!
Matt Miller
2020 SS 1LE |
06-01-2021, 10:09 PM | #110 | |
What makes you SURE there is no safety concern? Would you also suggest mounting a 305 on 9.5? 9.0? Where exactly does a safety concern kick in, based on your musings? The fact that some ppl mount tires beyond manufacturer specified range, doesn't mean it is a safe practice, or should be blindly copied, or condoned.The fact they get away with it doesn't prove anything, as who knows how they use their cars, or how far they push, etc. No matter how good a driver, or how well prepped a car, what keeps us safely connected to the pavement is just 4 small contact patches. There really is no good reason to push the envelope here just to save a cost of 2 rims. |
06-02-2021, 06:52 AM | #111 |
Just to add some of my own musings regarding load ratings being directly related to tire size and amount of air:
While this is the case with these 2 specific Falken sizes, this wisdom does not apply to all of them and in some cases smaller tires have higher ratings. So something else must play a role here, perhaps carcass construction, side wall stiffness, aspect ratio, etc. But to be clear: i am not sure. Also note, for example, A7 has much lower load ratings for comparable sizes vs street tires. Hoosier also recommends slightly different rim sizes too - in some cases - to make it even more complex. Another consideration is cold and hot tire pressure. It is no secret, that running pressures too low to improve performance can lead to tire failure. Happens in Nascar almost every race. Id imagine this to be even more influenced by incorrect rim size. Bottom line, i would never put an oversized tire on a front, given they work much harder than rears. Simply because this hobby already carries plenty of risk and i wouldn't want to wonder if i am gonna lose a tire while cornering at 100+ mph under extreme *lateral* loads. Another consideration, would be a potential risk for others following me. But that's me and my personal principles. Cheers! |
06-02-2021, 08:52 AM | #112 | ||||||
Another good reason to consider the 305/315 combo is the ABS system. Using the 275/305 combo increases the diameter split from front to rear. That may - may - induce ice mode more easily. If so, then the 305/315 combo would not. That alone is enough of a reason to consider the safety and consistency of the larger combo. I can tell you that I've gotten ice mode in my 2020 on the 275/305 combo whereas I did not on the stock Goodyears. That may have to do with the bigger size split, or maybe it's just down to the increased grip, slip characteristics, or other construction differences. I don't know. But that would be a reason to try the larger combo. I wish I had the funds to do a controlled test of the two combos on the same 1LE with a couple really consistent and fast drivers, a la the GRM tests that Whitener and Hollis do. It would be very interesting to directly compare times across temps and conditions. Unfortunately, I don't. I do agree that in general it's not ideal to mount tires on wheels that are narrower than the manufacturer rim width. However, that's based on performance and handling traits rather than safety concerns. I'm very confident that safety is not a concern. The problem here is that in certain competition classes we can't change rim widths and the current best tire option doesn't offer a "just-right" size option for the front of our cars. Covnersely, you could view the problem as being that Chevy should have made our cars with 11" square rim widths. That would have solved everything. But we have what we have, and we are just mulling over two imperfect-but-very-good choices. I had the option to try the larger size and chickened out because of the unknowns in performance. I will be interested to see mecorn's results!
Matt Miller
2020 SS 1LE |
