02-09-2021, 08:49 AM | #57 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
03-07-2021, 08:10 PM | #58 |
Drives: '19 Camaro 1LE 2.0 Turbo Join Date: Mar 2019
Are the 660s significantly wider than comparable 71r's? I've been running 275/35/r19 re71rs on 8.5" and 9.5" wheels for my 2.0 1LE to stay DS legal. I'm noticing the section width on comparably sized 660s is 0.4" wider. The Bridgestones were no problem, but should I be concerned about shoehorning the 275 Falken on the 8.5" wide fronts?
03-08-2021, 09:13 AM | #59 | |
Some are saying the sidewall seems softer than the RE71R, some are saying it's similar I can tell you that the 275 19"s fit more like a 285 on a 10" wheel and do look a bit pinched on a 9.5"... The TireRack dimensions certainly suggest the 265/35R19 RT660 is more in-line with a 275/35R19 RE71R. I have seen a picture of the RT660 255/35R18 on a 9.5" and it fit perfect/ever-so-slight stretch. I actually have on order 275/30R19 and 315/30R19 (can't source 305/30 for a while) in the RT660 for my SS 1LE (running 19x10/19x11). Seeing as you are in Detroit, you can take a look once autox starts up. If I were you, I'd run 265/275 or 265/265 in the RT660 on the Turbo 1LE. |
03-08-2021, 10:15 AM | #60 |
Drives: '23 Hyundai Kona N, '24 VW GTI Join Date: Aug 2019
I am thinking of 295/35/19 and 315/30/19 on 19x10 and 19x11 Apex ARC-8 w/ stock offsets. Anybody see any problems?
03-08-2021, 10:24 AM | #61 |
Drives: 2013 C6Z06 Join Date: Nov 2016
Strano ran them again on his vette at Summit Point and got almost identical laptimes vs G3s.
Old Ride: 2016 Callaway SC630 Camaro SS
03-08-2021, 10:46 AM | #62 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Fronts may be too tall.
03-08-2021, 10:56 AM | #63 |
Like in terms of clearance?
03-08-2021, 11:00 AM | #64 |
Ditto
27.2" front with a 26.3" rear... changing the rake of the car. should be better for drag racing. Let's look at it in maybe another way: 765 rev/mile front vs. 791 rev/mile rear Stock is a split of +14 rev/mile in respect to the front (front is 14 revs faster than rear), whereas you would be going -26 rev/mile in respect to the front (rear is 26 rev/mile faster than front). |
03-08-2021, 11:45 AM | #65 |
No, as Mountain said the OEM fronts are smaller vs the rears. You can run square but I would never run a larger diameter front vs rear on this car. You're probably better off with a stock-like stagger vs square, but you can rotate square, that's it's main draw.
Personally, I'd go 315/18 square on 11.5 or 12s using spacers + camber plates + grinding a bit of strut up front. Probably ~40 offset w/ 20mm spacers and +1" wheel studs, maybe 5mm spacers out back + moving the wiring. A bit of work, lol... Or stick with stock widths and offsets with 275/30 and 305/30, then you can keep the BS classification.
03-08-2021, 12:09 PM | #66 |
Drives: 20 SS 1LE Join Date: Jun 2020
The 285/35R19 front and 305/30R19 rear setup I ran last will definitely not play well with the PTM. As in it will only give you full throttle if you turn everything off. You'll need to either go square or keep the front smaller than the rear to take advantage of any of the traction management stuff. Works fine with it all off though - just looks a little weird.
John Hale
multi time solo nats runner up :( |
03-08-2021, 12:11 PM | #67 |
I'm loving the 275F/305R RT660 setup - two events in a row for top PAX, and I got FTD on the one this weekend. My car is all stock with alignment and the balance is great.
John Hale
03-08-2021, 12:13 PM | #68 |
Can confirm the RT660 275/30R19 runs wide and is pretty much exactly the same width as the 285/35R19 RE71R. The RT660 305/30R19 is not oversized and is exactly the same width as the 305/30R19 RE71R.
John Hale
03-08-2021, 01:11 PM | #69 | |
The various sensors are all there for a reason. OEs will harness the data as much as they can to get the vehicle to perform better/their criteria and these new vehicles have more linked systems than in the past... sure, there are likely allotted allowances in things like wheel speed deltas, but how tight those deltas are are likely reliant on the vehicle engineering team's collective decisions, with the potential usage of the vehicle in mind, and are really not known to the public unless someone tests various setups back-to-back. This isn't to say the car won't drive within, whatever, 95% of it's capability, but... I've heard of some "findings" on these newer vehicles after "weird things" happen, you're attempting 10/10ths and your setup is very off from OE setup expectations. Just saying. |
03-08-2021, 01:49 PM | #70 | |
Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
