06-20-2020, 12:34 PM | #1 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Soler Performance TB install issues
So I just installed my Soler TB and I followed the instructions perfectly. So I started the ECM relearn process when im 14 miles into it and my check engine light comes on. I connected my reader and code P0326.has anyone have this issue?
06-20-2020, 01:13 PM | #2 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Did you reconnect everything? If so, contact Mike and Soler, he is very responsive to requests for assistance.
06-20-2020, 01:23 PM | #3 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
I'm was about ready to pull the trigger on one of these for my V6, but I'm glad I saw this.
06-20-2020, 01:31 PM | #4 |
I did call Mike he was kind of confused on the code it is given me. He said try it again, I just did and 9 miles into relearn pops again. I guess I'm just putting the oem back on.
06-20-2020, 01:36 PM | #5 |
Are you running 93? Did you pinch a wire? That is a weird code to get...
06-20-2020, 02:30 PM | #6 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Too low octane + hot day + hard acceleration could throw that code. A pinched wire will throw that code too. It is a odd one to get for sure.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
06-20-2020, 03:21 PM | #7 |
I always use 93 octane, no pinch wires. I installed the oem back on and want out for a hard ride to issue no light. So I'm kind of confused myself. Can to much air flow throw that code? I have an roto fab intake, Soler TC .
06-20-2020, 03:26 PM | #8 |
We’re you driving lightly and cruise? The fuel trims have to do some work. Do you have a tool to clear the fuel trims?
06-20-2020, 03:42 PM | #9 |
06-20-2020, 03:46 PM | #10 |
Drives: chevrolet camaro Join Date: Aug 2019
i had the same issue didnt get that code but had issues. first time i did the relearn process i went to drive car and before it got out the garage CEL came on and reduced power mode. second time went thru entire process again and same thing didnt get out of garage and power reduced mode.
i was told they had a bad batch of TB. so they sent me out another but havent had time to install it yet will disconnect battery ond sunday and then do the relearn on monday hopefully all goes well!!! |
06-20-2020, 07:23 PM | #11 |
Get up with Mike again and have him send you a new one.
06-20-2020, 11:51 PM | #12 |
I will call Mike tomorrow and see if he can send me a new one.
06-21-2020, 01:57 AM | #13 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
If your car is stock and you install a PTB and get a code like this, then clear it and go back and forth a few times and at some point your car does its monthly data upload to GM and sends the code history, do you have to worry GM may deny warranty work if there are engine issues?
06-21-2020, 09:23 AM | #14 | |
