Roto-Fab
Old 03-30-2016, 11:02 AM   #29
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
3.91 gears
Now I'm not really shifting cause i got up to the gears speed more like the tire spin and and it hits the rev limiter.
On the reverse of this not sure I'd have it any other way cause its a blast to pull to some car next to and be going 80 and with about 3000 rpm on it the tires will spin if I mash it lol!
I want to track the car as in road course and or larger ovals with some turns.
You're definitely not doing your tires any glory with those 3.91 gears. I, like you, have a hard time on the road with street tires. 1st gear useless, 2nd gear a spinfeast, 3rd gets interesting top end (around 100mph), and I'm running the 3.73. The 3.73's seem really good but easy to spin the tires at the strip and on the street. Was hoping to get faster without spinning with a set like 3.23.
I think I'll go ahead and get some 3.23, keeping the 3.73 in case, and report back... Worse case, I will have a set of gears (3.23) for when a new forged and stroked motor go in, and bigger turbos!
As far as the road course tire question, have heard and seen the Michelin PSS run great, holding the turns. Seen them run at the strip on a modified ZL1 and they started off the line well, almost as good as the Nitto DR's I have (probably not saying much).
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 03-30-2016, 04:30 PM   #30
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
I got a good deal on a ZL1 rear, with the 323 gears in it, so I went with it, it was a hard deal to beat.
I wish I had some experience to give you on this, to tell you how I like it. But the truth is, I am waiting to see if I have shot myself in the foot by changing my gears or If I have made the right move. The car will be done end of April or first part of May.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 03-30-2016, 04:55 PM   #31
dreksnot
dreksnot's Avatar
You're "some" help, really.... Got the setup I'm wanting to know about but you're in the same position - not knowing how they'll (3.23) run, and the car in the shop.
Old 03-30-2016, 08:11 PM   #32
Unreal
Drives: 2006 Z06
If the 3.23 isn't enough, turn the boost up until it is
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 03-31-2016, 07:44 AM   #33
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
I like the way you think. LOL
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 04-01-2016, 08:54 AM   #34
1KillerSS
1KillerSS's Avatar
Sorry bud, I was really trying to say I'm interested in this thread because Im basically in the same shoes as you. I figured it was better than posting a popcorn emoji.
Build thread
Old 04-01-2016, 09:14 AM   #35
dreksnot
dreksnot's Avatar
I gotcha. Just giving you a hard time for your lack of ability to help since you were in the same boat. I did get the 3.23 RDM ordered so once delivered, installed and broken-in properly, I can report back to you as improvement or bust. Also going with poly front and Delrin rear bushings to keep 'er stiff on launches. I imagine I'll need to build up a few more pounds of boost to jump off the line. We'll see...
Old 04-01-2016, 03:40 PM   #36
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
I'm no help either. I got the ZL1 3.73 unit under the car now and a ZL1 3.23 unit on the shelf if needed.Haven't had a change to try the car yet due to weather. Mine is an Auto too. So it's not much help either.
lol...
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
