dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 07-13-2015, 03:28 PM   #1
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
DSS popping - normal?
I've had my DSS CF 1pc driveshaft and 1,400hp axles on for several thousand miles. Been to the strip a few times with them. Lately, I've noticed a quaint popping noise when starting out from a stop, or if I take off slowly then load it up, something makes a popping/pop noise (only once per starting off). [like something is binding then letting go].
I crawled under the car and checked for anything loose - didn't find anything.
Is this something normal for the DSS CV's on the axles or driveshaft? I've been told they're going to be noisier but is this normal for these?
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 07-13-2015, 04:13 PM   #2
MA2010SS
Drives: 2010 Camaro SS
popping no, noisier yes. I would check the CV joint at the trans, and both axles
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 07-13-2015, 04:21 PM   #3
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
Check the torque on the bolts on the axles
Driveshaftshop is offline   Reply With Quote
Old 07-13-2015, 04:30 PM   #4
dreksnot
dreksnot's Avatar
Bolts did not appear loose but I will check the torque on them. As for axle movement side-to-side - what is normal?
Old 05-26-2017, 06:48 AM   #5
HeavyChevySSRS
HeavyChevySSRS's Avatar
Drives: 2010 SSRS
Having the same issue with mine. Only underinitial load it's clicking. Once your moving you don't hear it.
As I lay rubber down the street I pray for traction k can keep, but if I spin and begin to slide please dear god, protect my ride[/I]
10' ls3 2SS/RS, gfx pkg, stainless headers, 3" stainless exhaust, rotofab cai, custom stage 3 cam, 4:11 gears, wall tuned
HeavyChevySSRS is offline   Reply With Quote
Old 05-29-2017, 02:00 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I get a slight click when going backwards.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 05-31-2017, 08:08 PM   #7
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
My driveshaft made a noise. There were 3 slightly loose bolts at the flange on the diff side. They allowed for just enough movement to make noise. Tightened them up and no noise.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
