Old 07-28-2017, 12:36 PM   #29
zryan
zryan's Avatar
Drives: 1973 z28 Rs, 2018 SS 1LE
Yeah that is my concern. No one needs to know how spirited my driving is.
2018 HBM SS 1LE Built 7/26: Black emblems, Smoked reflectors/lights, Dimple magnetic drain plugs, Carbon rock guards, Carbon fuel door, Elite Engineering Catch-can, BMR strut-brace,
zryan is offline   Reply With Quote
Old 07-28-2017, 12:48 PM   #30
fastball
Drives: 2017 Camaro 2SS 6MT
Pulling the fuse will work. The reason we are removing the board is to retain Bluetooth. When you pull the fuse you lose Bluetooth as well.
Don't guess with the antenna. If on the remote chance removing the antenna load doesn't ramp up the amplifier current in the radio you won't know that unless you had the schematics. Just remove the board.
fastball is offline   Reply With Quote
Old 07-28-2017, 12:51 PM   #31
zryan
zryan's Avatar
I'm thinking ill just pull the fuse and see if i can live without bluetooth. If not ill do the full removal. Thanks! Mostly just don't want them getting my data for free.
Old 07-28-2017, 01:01 PM   #32
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
this seems like a huge waste of time. What are you gaining for doing all this?
SSTony is offline   Reply With Quote
Old 07-28-2017, 02:01 PM   #33
fastball
Cars have become rolling communications dataports. If you're good with that more power to ya. I'm not.
Old 07-28-2017, 09:29 PM   #34
PinHead
Drives: Duramax
Originally Posted by fastball View Post
Cars have become rolling communications data COLLECTION ports. If you're good with that more power to ya. I'm not.
There, I fixed it for ya. I totally agree that people do not realize how much data is collected THEN DISSEMINATED OUTSIDE OF GM.
PinHead is offline   Reply With Quote
Old 07-29-2017, 12:13 AM   #35
fastball
Ah yes, that you for fixing that. You're exactly right.
Old 07-30-2017, 09:27 AM   #36
zryan
zryan's Avatar
I agree entirely with the above. Not a fan.
Old 08-27-2017, 08:39 PM   #37
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Old 09-07-2017, 08:15 PM   #38
Franko07
Drives: 17 white 1LE
where does the bluetooth come in at? i would rather pull the fuse so that the mirror lights dont come on but if i could run a jumper wire somewhere for bluetooth that would be ideal
Franko07 is offline   Reply With Quote
Old 09-08-2017, 10:20 AM   #39
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
You do not lose bluetooth when you pull the fuse. You only lose the mic input.
You remove the transponder to retain the mic while losing the ability for onstar to connect to it's network.
Old 12-05-2017, 04:02 PM   #40
nasbagoat
Drives: 17 SW 1LE
I agree with most of the sentiments here, I do however like the PDR with GPS tracking/ lap timer. I assume if I follow this procedure then this feature will be disabled?
nasbagoat is offline   Reply With Quote
Old 12-07-2017, 12:33 AM   #41
cellsafemode
Indeed. You are disconnecting the antenna by removing the module.
You can disconnect just the radio antenna but I'm not sure how well the gps will work without being assisted by the cell radio connection. And disconnecting just the antenna could damage the transmitter hardware and may still allow a connection.
If you don't need to use the mic, you can go with the fuse method.
Old 12-07-2017, 05:59 AM   #42
fastball
The only reason most people use bluetooth is for hands free cell phone calls, and for voice operation of their cell phone. So for all intents and purposes when you lose the mic you lose bluetooth.
