07-12-2023, 11:11 AM | #2129 | |||||||
Drives: Chevrolet Camaro SS 1LE Join Date: Apr 2019
Tom Fronk Track Time
Track (which config if applicable) = Daytona Road Course
Elapsed Time (please include times to the hundredth if possible) = 2:03.72 Year / Model / Trim / Transmission = 2018 Camaro SS 1LE Manual Date = 12/11/22 Tires = Goodyear SC3 OE Sizes Mods = Heads, Cam, Long tube headers, Intake, camber plates. Track (which config if applicable) = VIR Full Course Elapsed Time (please include times to the hundredth if possible) = 2:02.91 Year / Model / Trim / Transmission = 2018 Camaro SS 1LE Manual Date = 6/21/22 Tires = Goodyear SC3 OE Sizes Mods = Heads, Cam, Long tube headers, Intake, camber plates. Track (which config if applicable) = VIR Grand Course Elapsed Time (please include times to the hundredth if possible) = 2:52.79 Look at the 11:43 and the 14:37 mark in video Year / Model / Trim / Transmission = 2018 Camaro SS 1LE Manual Date = 3/15/22 Tires = Goodyear SC3R OE Sizes Mods = Heads, Cam, Long tube headers, Intake, camber plates. Track (which config if applicable) = AMP Elapsed Time (please include times to the hundredth if possible) = 1:36.18 Year / Model / Trim / Transmission = 2018 Camaro SS 1LE Manual Date = 5/19/23 Tires = Goodyear SC3 OE Sizes Mods = Heads, Cam, Long tube headers, Intake, camber plates. Track (which config if applicable) = Summit Point Shenandoah Elapsed Time (please include times to the hundredth if possible) = 1:45.83 Year / Model / Trim / Transmission = 2018 Camaro SS 1LE Manual Date = 8/18/21 Tires = Goodyear SC3 OE Sizes Mods = Heads, Cam, Long tube headers, Intake, camber plates. Track (which config if applicable) = Road Atlanta Elapsed Time (please include times to the hundredth if possible) = 1:39.3 Year / Model / Trim / Transmission = 2018 Camaro SS 1LE Manual Date = 10/25/20 Tires = Goodyear SC3 OE Sizes Mods = Stock Track (which config if applicable) = Charlotte Motor Speedway Elapsed Time (please include times to the hundredth if possible) = 1:23.74 (7:35 marker in video) Year / Model / Trim / Transmission = 2018 Camaro SS 1LE Manual Date = 9/27/21 Tires = Goodyear SC3 OE Sizes Mods = Heads, Cam, Long tube headers, Intake, camber plates. |
07-12-2023, 12:09 PM | #2130 |
Driver for Hire
All times updated
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21 2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20 YouTube Channel |
07-13-2023, 03:43 PM | #2131 |
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
07-16-2023, 11:52 PM | #2132 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Here's a new track to add to the list!
Track (which config if applicable) = G2 Motorsports Park - Full Course (No Chicane) - Anna, TX Elapsed Time = 2:26.95 Year / Model / Trim / Transmission = 2017 1SS 1LE M6 Date = 7/15/2023 Tires = OEM Goodyear Supercar 3 Mods = Track alignment (camber: -2.2° front, -1.8° rear, toe: +0.05° per side front, some toe in for the rears), SPL Rear Toe Links + Eccentric Lockout, BMR BK063 Rear Diff Cradle Bushing Lockout Kit, FEA front lower front control arms from ZL1 1LE (since stock fluid filled bushings leaked), 2021 SS 1LE ABS control module (EBCM) to get better ice mode calibration (found on 2019+ SS 1LEs) which prevents intermittent hard brake pedal and reduced stopping force in bumpy braking zones, Castrol SRF DOT 4 brake fluid, stock Brembo (Ferodo HP1000/1) brake pads, GM plastic track brake cooling deflectors, GM smaller metal track splash shields. PTM Sport 2, track mode with touring steering mode. 2:26.95 - cdrptrks in '17 1SS 1LE M6 on 7/15/2023, OEM SC3, Track alignment, SPL Rear Toe Links + Eccentric Lockout, BMR BK063 Diff Lockout Kit, FEA front lower front control arms, 2021 SS 1LE EBCM, Castrol SRF brake fluid, GM track brake cooling kit Video It is a great new track with completely smooth pavement in the Dallas, TX area! It is advertised as a members only facility (which I can't afford) so I jumped at the chance to drive it while the buildings are still under construction. Hopefully the track will eventually offer some type of track day / HPDE events open to the public so more people will get the chance to experience this impressive track although I am not currently aware of any plans for public events. There is a nice variety of corners and a good number of them are challenging. I especially enjoyed the adaptations of the heavily banked carousel from the Nurburgring and turn 5a/5b from Mosport! This is not my best driving but I was starting to get the hang of this track and I think I did ok considering it was my first time at this track. Plus I drove for less than an hour total including cooldown laps with just a short break between my first and second session. Note that my line is probably not optimal as I was still experimenting with it in different places plus I missed some apexes. Sorry the PDR track map and lap timer overlay only worked during the first session not the second one but I put a screenshot of the track map with the red dot at the start/finish line which is roughly where the video starts and ends. Note: Cosworth Toolbox shows this track layout as 2.96 miles. I guess the 3.1 mile distance mentioned on the track's website may be counting the chicane. Cosworth is usually within a few hundredths of a mile of the advertised lengths of other tracks I have been to. It can also be split into two independent tracks: 1.9 mile west track and 1.2 mile east track. |
07-17-2023, 11:52 AM | #2133 |
Driver for Hire
All times updated, but we have a slight problem...
Character limit on the list is 100,000 and we have surpassed that. My initial remedy is to remove times past "top 20" and that gives some space back. (Don't worry, I have saved those times in a document.) I will have to go through and see where I can cut out some characters but limiting to top 20 may not be enough as this list grows. No immediate resolution at the moment but I will keep everyone informed.
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21 2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20 YouTube Channel Last edited by FollowMyLine; 07-18-2023 at 08:53 AM. |
07-17-2023, 12:02 PM | #2134 |
Hmm maybe a moderator can give you control of post 2 so you can split the list into 2 posts giving you another 10,000 characters to work with and you can quote the original text of post 2 at the bottom?
Or you could create a new thread and post a few comments reserved for future use then cut/paste the list into the new thread split across the first 2 comments and put a link to the new thread in post 1 of this thread. |
07-17-2023, 12:12 PM | #2135 |
Driver for Hire
Secondary update:
spaces count as characters, so I have eliminated some text, shortened some track names and added the times back in past top 20.
Luan Zeqollari
07-17-2023, 12:15 PM | #2136 | |
Driver for Hire
Luan Zeqollari
07-17-2023, 01:41 PM | #2137 |
Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
07-18-2023, 08:49 AM | #2138 |
Driver for Hire
Update on character count:
I have gone through and eliminated some of the fluff. I was able to get us from over 100,000 characters down to 97,681. I will continue to go through each track time and eliminate things like spaces where they are not needed (for example Hawk DTC 70 / DTC 60 can be replaced with Hawk 70/60) and continue to eliminate words like "pads" or "fluid" when talking about DS1.11 pads and Castrol SRF fluid, as another example. Update again: down to 95,861. I think we are good for a while.
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21 2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20 YouTube Channel Last edited by FollowMyLine; 07-18-2023 at 08:59 AM. |
07-21-2023, 10:41 PM | #2139 |
Laguna Seca 7/21/23
E.T. 1:39.58 17 SS Mods- Cam heads FBO E85, DTC70 ZLE brakes, Silvers 2 ways, Nankangs AR1 315/30/18 square, APR GTC 300, custom splitter. https://youtu.be/UbKKbti0syA |
07-23-2023, 08:43 PM | #2140 | |
Drives: 2022 SS 1LE Join Date: Jun 2023
https://youtu.be/bjkXq5qjT90?t=156 Here is my submission: E.T. 1:38.68 22 1SS 1LE Mods- Apex VS-5RS 19x11/12 ZLE 3R Vorshlag Plate 3.3f/-2.1r camber SPL RUA/Rear Toe w/lockouts CT XP20 f pads Endless RF-650
2022 White SS 1LE - stock power
Track Videos |
07-23-2023, 11:26 PM | #2141 | |
So that was you!! You were flying out there, couldn't catch you but it helped me get a new PB. |
07-24-2023, 01:08 AM | #2142 |
congrats on your new PB! hope to see you out there again.
Track Videos |
